1. AC Question's Avatar
    when i plug phone into the cord it charges, when i put the phone on the pad it wont. when i plug the plug into the pad it does light up but wont charge the phone. What gives?
    I've had the pad for a bout 2 months and always worked fine and suddeny stopped
    06-28-2016 11:26 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Which Samsung phone do you have? Did it come with wireless charging, or did you have to use a kit to make it compatible? Is the charging pad an OEM Samsung pad, or is it from a 3rd party manufacturer?
    06-28-2016 08:58 PM
  1. How can I fix a microphone issue I am having with my S7?
    By AC Question in forum Samsung Galaxy S7
    Last Post: 06-28-2016, 09:05 PM
  2. Replies: 1
    Last Post: 06-28-2016, 08:59 PM
  3. Screen times out and makes lock noise
    By popkurn611 in forum Samsung Galaxy S7
    Last Post: 06-28-2016, 08:55 PM
  4. Replies: 1
    Last Post: 06-28-2016, 01:00 PM
  5. Replies: 1
    Last Post: 06-28-2016, 12:58 PM
