- 03-11-2011, 07:10 AM
Thread Author #1
- 04-29-2011, 10:10 AM #2
- 05-03-2011, 05:04 PM #3
I rooted my WFI xoom a couple of days ago and now I want to go back to stock and relock. When I follow the directions listed here I get an error that the boot.img can't be loaded. I am using HWI69 which is also what it is running currently. Thanks in advance for any help.
- 05-13-2011, 12:48 AM #4
- 05-21-2011, 09:05 PM #5
- 06-27-2011, 08:18 PM #6
- 07-29-2011, 02:00 AM #7
Re: [Guide] Unroot and re-lock Xoom via fastboot and official sys
This is good info to know... so you can not update if u are unlocked and rooted? I rooted just to install adfree android and remove unwanted apps...
- 07-30-2011, 01:26 AM #8
- 08-12-2011, 02:34 AM #9
- 02-02-2012, 07:19 AM #10
Mine failed at flashing system.img
"Failed to process command error (0x120003)"
Any help, anyone?
EDIT: I flashed the system.img again and was able to proceed... all else went exactly as written, but after doing the relock, the system comes up to the batwings
and says "Failed to boot LNX 0x0004
Starting RSD Mode 2"
Any suggestions now, a reset takes me right back to same screen... I can't even get to bootloader anymoreLast edited by Chuckroid; 02-02-2012 at 07:34 AM. Reason: got further along
Motorola Droid RAZR GB 2.3.6
Motorola Xoom Honeycomb 3.2.4 64GB 4G LTE - 06-05-2012, 09:34 AM #11
You can still get to fastboot. You need to hold the power and vol down button until the error appears. It will then go into fast boot. From there you can use the command line again.
- 07-16-2012, 09:47 PM #12
- 07-24-2012, 01:52 AM #13
- 08-31-2012, 05:41 PM #14
- 11-24-2012, 08:16 AM #15
Reply
