Results 1 to 4 of 4
- 04-27-2011, 03:19 PM
Thread Author #1
Overclocking Xoom Help
I have followed all the directions, but cannot get past the adb reboot bootloader command. It won't recognize it. I am rooted. I downloaded and unzipped xoom_ocboot and android sdk. In USB debugging mode, computer is now recognizing Xoom. What is the problem?
- 04-28-2011, 08:29 AM #2
I'm probably forgetting something, but doesn't the current root method automatically flash and use the tiamat kernel? If so, you can just grab SetCPU or a similar app to OC.
Sent from my Xoom using TapatalkThanked by: - 04-28-2011, 09:52 AM
Thread Author #3
You are correct, thank you. Does this include sd card support too?
- 04-28-2011, 08:09 PM #4
The kernel has SD working. Just follow all the steps and your good. It will keep you at 1.5 so if you want to go lower use setcpu.
Sent by Xoom
Reply
