UNOs ipower31 has 8000mAh power bank charger for android / iphone,
Worry-free no more low capacity.
This power bank has two USB, can charge nexus / android table in the same time, and it is has a good shape.
Lithium polymer Battery inside, better than 18650 battery,
it's portable, put it in your bag, or pocket ( maybe) ,Dimension is 138x68x17mm.
You will like it !
look the detail to know more:
unos ipower31 power bank
BatteryType: lithium polymer Battery
Power capacity:8000mAh
Input: 5V/2.0A(max)
Output:5V/1.0A
Output2:5V/2.0A
Weight: 180g
Dimension: 138x68x17mm
Working Temperature: -10.C to + 55.C
Made in China, also, high quality, hight capacity
You will like it !
Input: 5V/2.0A(max)
Output:5V/1.0A
Output2:5V/2.0A
Weight: 180g
