1. iKokomo's Avatar
    I know this is not a cell phone, but the principle seems to be the same if you have a phone with a proprietary USB charger that is missing.
    Someone gave me a swimming, underwater Finis Neptune MP3 player but the problem is the charging cable was not included. Since this is a waterproof MP3 player the cable is proprietary and it is impossible to find a cable (from the company or otherwise) without buying a second unit on eBay with the cable.
    My 1st question: Is there a way to cut apart an old USB cable and make my own charger/transfer cable? How do
    My 2nd question: There are four contacts on the bottom of the MP3 player. How do I map each one to know what is positive, negative, ground and data transfer? (Photo of pins attached)
Thanks!
    05-31-2019 04:58 PM
  2. hallux's Avatar
    With a connection like the one shown your best results will be to find the proper mating connector to wire up. On the up-side, if you can find the connector it may have matching wire colors to those found in a standard USB cable so it may be easier.
    You'd need to find a schematic of the device (maybe on an FCC filing?) that details the pin mappings for that connector.
    05-31-2019 05:10 PM
  3. Rukbat's Avatar
    You have to find a mating connector - if it's USB (it may not be - 4 pins doesn't automatically mean USB), but the Duo charging cable may work (the picture is more detailed than your picture if you roll over it with your mouse cursor - take a look). It's US$20 (plus shipping), which isn't bad for a proprietary cable. Or contact Finis at:
    USA
    FINIS,Inc.
    7085-E Las Positas Road
    Livermore, CA 94551
    Phone: +1(925)454-0111
    Fax: +1 (925) 454-0066
    Email: info@FINISinc.com
    EU
    FINIS,Inc.
    Malashevska Str.
    No.8 Store E2
    Sofia 102, Bulgaria
    Phone: +359 2 936 86 36
    Or submit a support ticket at https://www.finisswim.com/contact-us, asking how you can get a charging cable for the Neptune if the Duo cable won't work with the Neptune.
    05-31-2019 05:35 PM
  1. Can't migrate data to SD card with Moto G5
    Last Post: 06-02-2019, 01:20 PM
  2. Moto G7 Power - Tap to Wake
    By Android Central Question in forum Moto G
    Last Post: 06-02-2019, 10:36 AM
  3. how can i use my smartwarch without a sims card
    Last Post: 05-31-2019, 04:49 PM
  4. When S10+ connects in car it dials itself - how to stop
    Last Post: 05-31-2019, 04:29 PM
  5. Moto G7 Power - Tap to Wake
    Last Post: 05-31-2019, 12:21 PM
