1. Jakub Doktor's Avatar
    I was charging my phone(Acer liquid Z630S) and the percentage went down to 0%.
    I left it on the charger so it could charge up(because it helped me last time it happened, this is the 2nd time) but it never did and it started boot looping.
    I cant wipe partition cache because the screen doesnt turn on at all. I tried to charge it from the wall plug and my powerbank. when it tries to turn on the ir light sensor turns on for a while. When I try to get in to the boot settings I get the vibration it does but the screen doesnt turn on.
    I dont have a spare battery to try to troubleshoot. thanks for help in advance.
    08-23-2018 10:35 AM
  2. Rukbat's Avatar
    Leave it turned off. Plug in the charger. Walk away, and leave it alone for at least 4 hours.
    At that point it should turn on, even if just long enough to boot to the point that you can see the launcher.
    In the future, keep the battery between 40% and 80%. (Overcharging - to 100% - isn't as bad as discharging to 0 [which can kill a brand new battery in a month], but it still shortens the battery life.) Seriously. If the battery drops below 40%, and you can't plug it in, turn it off. Or start buying batteries by the 10-pack. Lithium batteries are not deep-discharge batteries.
    Jakub Doktor likes this.
    08-23-2018 01:04 PM
  3. Jakub Doktor's Avatar
    thanks for the help my problem happened like 4 days ago but like 5 hours it finnaly booted up again. Thank you very much for the help.
    08-24-2018 02:49 AM
  1. What is the kik-result file in my files
    Last Post: 08-26-2018, 07:33 PM
  2. Picture showing in gallery i did not take.
    By Scott Costley in forum Samsung Galaxy S7 edge
    Last Post: 08-23-2018, 12:47 PM
  3. First Impressions - Note 9 Battery Life vs Note 8
    By corvette72778 in forum Samsung Galaxy Note 9
    Last Post: 08-23-2018, 11:05 AM
  4. Note 9 Buyers in India
    By jeetu4444 in forum Samsung Galaxy Note 9
    Last Post: 08-23-2018, 10:19 AM
  5. Replies: 1
    Last Post: 08-23-2018, 09:41 AM
