1. SactoKingsFan's Avatar
    The LED notification light on the idol 3 seems to only work with missed calls, messages, charging and low battery alert. I've tried light flow, led blinker and an xposed mod to use LED notification with Gmail and some other apps but none of them work. Anyone know of an app that allows us to enable or disable LED notifications for specific apps?
    Sent from my 6045I using Tapatalk
    10-04-2015 11:15 PM
  2. srkmagnus's Avatar
    The LED notification light seems to only work with missed calls, messages, charging and low battery alert. I've tried light flow, led blinker and an xposed mod to use LED notification with Gmail and some other apps but none of them work. Anyone know of an app that allows us to enable or disable LED notifications for specific apps?
    Try Light Flow: https://play.google.com/store/apps/d...ightflow&hl=en
    I took a quick look and I don't think it requires root access; however, you may need to try it out and verify that it works with your model Alcatel device. Let us know if that works and if it's what you are looking for.
    10-04-2015 11:27 PM
  3. SactoKingsFan's Avatar
    Looks like light flow works on the idol 3 but it won't let me select certain apps.
    Edit: just installed light manager and it works like light flow and I can enable the LED notification light for any app that has notifications.
    srkmagnus likes this.
    10-04-2015 11:52 PM
  4. srkmagnus's Avatar
    Awesome! Is that what you were looking for? It's a little hassle to have to search for a third-party app...but that's the benefit of using the Android ecosystem: choice/options!
    SactoKingsFan likes this.
    10-06-2015 10:41 AM
  5. SactoKingsFan's Avatar
    Yeah, light manager does exactly what I wanted.
    10-06-2015 07:25 PM
  1. Replies: 41
    Last Post: 09-24-2016, 09:33 AM
  2. Did anyone order the Zenwatch 2 from google?
    By cert15z in forum ASUS ZenWatch 2
    Last Post: 10-08-2015, 12:40 PM
  3. Why is the Vibration not working on my Samsung Grand Mobile?
    Last Post: 10-05-2015, 02:11 AM
  4. How can I fix my microphone?
    Last Post: 10-04-2015, 11:44 PM
  5. Replies: 1
    Last Post: 10-04-2015, 11:40 PM
