1. anon(9633271)'s Avatar
    In a previous thread, i shouted from the roof tops that the 5042T finally has a rooting method.
    http://forums.androidcentral.com/alc...hout-root.html
    Having done the above, i've been using KingRoot's SU app for a couple weeks.
    While it certainly gets the job done, it just can't compete with SuperSU. (Imho)
    Then of course there's the worry surrounding what data it collects and sends back to China.
    KingRoot however, isn't keen on having their SU app replaced and makes it notoriously difficult to do so.
    After days of searching and reading and putting it off, i finally got the nerve up to try the method i devised.
    i'm happy to say that it worked and went way smoother than i had envisioned.
    So, if you have the 5042T with KingRoot but would rather have SuperSU, head on over to my G drive.
    Everything you need should be there.
    https://drive.google.com/folderview?...mJrbW5lZVFuWFE
    03-12-2016 11:12 AM
  1. Replies: 2
    Last Post: 09-04-2016, 10:58 PM
  2. Is there a way to minimize the "ok Google" strip?
    By paulphilly in forum Samsung Galaxy S7 edge
    Last Post: 03-13-2016, 10:34 PM
  3. Downloaded files - how to manage them
    By tlothian in forum Moto X Play
    Last Post: 03-12-2016, 01:07 PM
  4. Replies: 0
    Last Post: 03-12-2016, 11:03 AM
  5. From iMessage to s7 edge
    By uawildcat in forum Samsung Galaxy S7 edge
    Last Post: 03-12-2016, 10:40 AM
