1. thenevaehshow's Avatar
    So a few days ago i went to the best buy bin and i found this Alcatel One-Touch Evolve and it had no sim card or a back cover but it did have the battery. And when i brought it home the battery kept on falling out. and yes it is the RIGHT battery. so i tried to tape the battery inside the phone, but it wont turn on. and i do have 2 other sim cards if needed. and when i try to charge the phone a white LED light comes on at the top and i dont know what that means... and i dont know if its Water damaged or if the battery is bad. please get a hold of me ASAP!! i really want this phone to work. Thanks!!!
    02-25-2018 12:43 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! In case the phone needs the back cover to be intact, you could buy a replacement cover for about $10: http://forums.androidcentral.com/e?l...token=TAWIndqd.
    Replacement batteries are also cheap (about $10): https://www.amazon.com/Alcatel-Batte...cUvbUpU6172133. It's hard to know if your battery is actually dead, so it's worth a try.
    Unfortunately, there's no way to tell if the phone has water damage (unless perhaps if you open the whole thing up).
    thenevaehshow likes this.
    02-25-2018 06:22 PM
  3. thenevaehshow's Avatar
    Ok, but when i put on the back cover on the phone does the battery still need to be taped up? and can i tape a old cover from a old phone onto the alcatel??
    02-26-2018 11:48 AM
  4. B. Diddy's Avatar
    My guess is that the battery doesn't have to be taped in place with the back cover on -- but you won't know until you try. Since every phone is different, you really need the back cover designed for that phone in order for it to fit properly.
    02-26-2018 01:19 PM
  5. thenevaehshow's Avatar
    ok great thanks for the tip
    B. Diddy likes this.
    02-27-2018 09:05 AM
  1. When yahoomail opening to Showing can't connect to server why?
    Last Post: 02-25-2018, 06:25 PM
  2. When yahoomail opening to Showing can't connect to server why?
    Last Post: 02-25-2018, 02:47 PM
  3. Contact added from dialer does not show up in contacts
    Last Post: 02-25-2018, 12:49 PM
  4. Replies: 1
    Last Post: 02-25-2018, 12:44 PM
  5. How can I tell what has been my
    Last Post: 02-25-2018, 11:51 AM
