1. T0350CK's Avatar
    I got a new phone but it's the exact same model as my old one..
    Alcatel verso..
    But for some reason if I put in an sd card, it shows up fine for the most part, but the internal storage says 0.0b of 0.0b..
    If I remove as card it says "storage/emulated/0 not found" and I can't access anything..
    And on my PC, the sd card shows up but the internal shared storage isn't recognized..
    I can't even provide screenshots to help because it says there's no room in internal storage...
    And I also don't understand how I'm on an app, with no internal storage to hold the app supposedly..
    What do I do?..
    02-07-2019 05:57 AM
  2. methodman89's Avatar
    First, remove the SD card and clear the cache partition and reboot. Then, see if you can dl Data Size Explorer and run it for internal storage. Post a screenshot of the result. Good luck
    02-07-2019 06:33 AM
  3. B. Diddy's Avatar
    Welcome to Android Central! Does this happen with any SD card, or only that one?
    02-07-2019 11:20 AM
  4. T0350CK's Avatar
    All sds
    02-07-2019 10:18 PM
  5. B. Diddy's Avatar
    Did you format the card to be Internal Storage or Portable Storage?
    02-07-2019 11:04 PM
  6. T0350CK's Avatar
    I have tried it both ways with different sd cards..
    As internal makes the phone show 14gb total but shows no sd storage and the sd card alone is 18 GB and it's empty..
    As portable it shows no internal but the sd memory is correct.
    02-08-2019 03:25 AM
  7. B. Diddy's Avatar
    Have you tried other SD cards? That particular card might be corrupt, defective, or counterfeit.
    02-08-2019 03:38 AM
  1. I cannot find a Case for my 3d Full glass screen protection
    Last Post: 02-07-2019, 07:41 AM
  2. Replies: 1
    Last Post: 02-07-2019, 05:37 AM
