1. officially_juju's Avatar
    I own the Alcatel One Touch Idol 3 along with a Pebble Time Steel. A weird thing has started happening this week as half my incoming calls are not showing up on my phone yet ring on the watch??
    Does anyone know of this issue with Lollipop? It's very odd as my watch will vibrate with the call but the phone acts as if nothing is coming through.
    Thanks!
    02-29-2016 06:19 PM
  2. B. Diddy's Avatar
    See if you can wipe the cache partition. Hopefully, the steps for the OneTouch Fierce work for the Idol 3: https://support.t-mobile.com/docs/DOC-11694
    03-01-2016 02:00 PM
  3. Lynnae evans's Avatar
    Ok i have figured it out on my simple mobile pixil from alcatel um heres what yall need to do if your incoming calls maybe on block setting but if they arent showing up on your home screen go in your home screen settings then scroll down from wifi exc. Exc. Go down to the sounds and notifications click on that and scroll down some more until you see App. Notifications tap on that scroll down until you see the call or dialer it might be a block click on that and slide the button slider to off where it says never show notifications from this app. I turned it off and now my incoming calls are back and working on my home screen i can finally enjoy playing games and seeing whos calking me incase i dont wanna answer i can dismiss it have a breath taking relaxing day after you finally know now what to do now
    04-05-2017 12:25 AM
  4. Lynnae evans's Avatar
    04-05-2017 12:40 AM
  5. Srinivas mulastham's Avatar
    My mobile is billion capture plus
    01-16-2018 05:07 AM
  6. 09056782288's Avatar
    I own the cherry mobile FB 100,,I have a incoming call but not showing up on my phone yet ring on the wacth and vibrating with the call.but my phone act like as if nothing is coming through. Thank you
    Bonnie-Clyde 13 likes this.
    01-16-2018 11:50 PM
  7. kholofelon's Avatar
    Thank you VERRRRY Much Lynnaes solution worked 110%!!! No.1 recommended solution guys! quick n easy
    07-27-2018 03:52 AM
  8. kholofelon's Avatar
    Thanks worked perfectly!!
    07-27-2018 03:53 AM
  1. Replies: 9
    Last Post: 01-01-2017, 08:01 PM
  2. Replies: 4
    Last Post: 03-07-2016, 12:17 PM
  3. Message when re-satrting or powering on
    By bushiee in forum Samsung Galaxy A5
    Last Post: 03-04-2016, 12:47 PM
  4. Text to speech icon not showing, how can I get it to show?
    Last Post: 02-29-2016, 07:01 PM
  5. Replies: 1
    Last Post: 02-29-2016, 06:59 PM
