1. relztrah's Avatar
    Total newbie question #2: I'm on the Ultra $19/mo plan (for this month anyway) with only 100MB of data. I only need this much data because I'm nearly always around wifi. I can see the antenna indicator showing that I'm on wifi, but how do I know when I'm using my cell data? And will my One Touch default to wifi when I'm within range of a recognized network?
    Also, is there a built-in app or widget or something showing me how much data I've used or do I download one from Google Play Store?
    Thanks for your help.
    10-22-2014 09:46 AM
  2. Golfdriver97's Avatar
    Welcome to the forums. Your status bar should show LTE next to your signal. Otherwise, you can check in Settings>about device>Status.
    As for how much Data you have used, you can check that in Settings>Data Usage
    10-22-2014 09:56 AM
  1. Why doesn't my phone have a recovery mode or downloading mode?
    By hedii janson in forum General Help and How To
    Last Post: 10-04-2016, 07:08 AM
  2. My phone still not update to the new Play Store
    By Omer San Gabriel in forum Samsung Galaxy S4
    Last Post: 10-22-2014, 03:15 PM
  3. How do I permanently turn off the power save mode on Galaxy S4?
    By Barry Carter in forum General Help and How To
    Last Post: 10-22-2014, 11:07 AM
  4. Do I need to charge my phone before I use it the first time?
    By Justin Linscott in forum Samsung Galaxy Note 4
    Last Post: 10-22-2014, 09:44 AM
  5. Miss my IPAQ and hope Note 4 is the answer
    By rhinodyson in forum Samsung Galaxy Note 4
