Folks,
I recently bought an Echo Dot mount/holder for my Amazon Echo Dot. It allows you to mount your Dot on a wall where you have an electrical socket. This is a really fun accessory. I have mine mounted in my kitchen.
The mount is constructed of mostly plastic with a bit of rubber where your brick connects to the outlet. It comes with a short USB cord to use with your brick (you'll need the brick that came with your echo for the best fit, but you should use the cord they provide. The Echo snaps in to the ring holder pretty easily BUT securely.
I'm using it for my kitchen and living room needs. I can get recipes, listen to music or my news briefing, and control my smart plug (my living room light), and control my Fire TV. This holder is perfect for my needs. It's also very reasonably priced. Check it out at Amazon.....
Bcway Outlet Wall Mount Hanger Stand for Dot 2nd Generation
