1. jwlary's Avatar
    I'm in the US and I've recently purchased an unlocked (GSM) Fire Phone and am trying to get it to work with data on H2O wireless. I can take the same sim out and pop it into my Windows Phone and connect just fine and use data. I've copied the apn and mmsc settings over to the Fire Phone and I cannot get it to use data. Has anyone successfully set up the Fire Phone for H2O wireless' apn and mmsc?
    Thanks, Jeff.
    02-25-2015 11:46 AM
  2. connie2000's Avatar
    My Fire Phone s on H2O wireless, and voice, data and MMS all work.
    03-05-2015 02:30 PM
  3. jwlary's Avatar
    Connie2000,
    Thanks for the response. What are the settings that you're using?
    03-06-2015 07:02 AM
  4. connie2000's Avatar
    APN Settings:
    APN: att.mvno
    Proxy: Not set
    Port: 80
    Username: Not set
    Server: not set
    Password: not set
    MMSC: http://mmsc.cingular.com
    MMS proxy: proxy.mvno.rpmobileweb.com
    MMS port: 80
    MCC: 310
    MNC: 410
    authentification type: not set
    APN type: default,mms,supl,hipri
    APN protocol: IPv4
    APN enable/disable: APN enabled
    Bearer: Unspecified
    These were automatically set up. I didn't change anything.
    jwlary likes this.
    03-06-2015 07:22 AM
  5. jwlary's Avatar
    This was the one that was present along with one for AT&T and maybe another one. I tried that one and could not get data to work. I think that I'll try resetting the phone and giving it another go. Thanks again for your help.
    03-06-2015 07:42 AM
  6. connie2000's Avatar
    Is your wifi off when you try to use data?
    03-06-2015 08:15 AM
  7. jwlary's Avatar
    Yes, wifi off and data enabled. When I pop the same sim into my other phone I'll immediately see 4G pop up, with wifi off and data on.
    03-06-2015 09:55 AM
  8. connie2000's Avatar
    I have an Ascend Mate 2 also on H2O, and it uses the AT&T APN. Have you tried the AT&T
    one?
    03-06-2015 12:56 PM
  9. jwlary's Avatar
    Yes, I tried the AT&T, the H2O, and the StraightTalk APNs. I picked up a sim from Ting, who are beta testing their GSM network and that works fine - LTE and all. I'm trying the reset now and if that doesn't work then I'll have to decide whether to keep it and use Ting. I really like the phone but this gets frustrating after a while. Thanks.
    03-06-2015 02:56 PM
  10. Tristan Renard's Avatar
    Hi there !
    Try this if it's still not working. I'm on a $60 unlimited plan with H2O and data would work on my new Amazon Fire Phone. I just chatted with customer service and the new credentials they gave me work perfectly fine ! Hope it works for you.
    APN: PRODATA
    MMSC: h ttp://mmsc.mobile.att.net (remove space)
    MMS proxy: proxy.mobile.att.net
    MMS port: 80
    MCC:310
    MNC: 410
    Authentication Type: None
    APN protocol: IPv4
    Bearer: Unspecified
    ENJOY !
    jwlary likes this.
    03-10-2015 08:09 PM
  11. jwlary's Avatar
    I can't believe it! I've tried every variation of what is put out for H2O and yours is the only one that worked for me. Thank you very much for taking the time to reply. I was at the point where I was seriously considering getting rid of the phone as I wanted to stay with H2O and I didn't need a 4.7" tablet.
    Jeff.
    03-12-2015 05:16 PM
  1. Can I download Google Play apps on my Kindle 3g?
    Last Post: 02-25-2015, 03:30 PM
  2. Replies: 1
    Last Post: 02-25-2015, 03:09 PM
  3. Replies: 1
    Last Post: 02-25-2015, 11:07 AM
  4. Replies: 3
    Last Post: 02-25-2015, 10:30 AM
  5. Replies: 0
    Last Post: 02-25-2015, 10:25 AM
