1. psongman's Avatar
    Hi, hope you can help. My Amazon firestick 2nd generation won't recognize the wired connection I setup using the otg cable. It keeps wanting to ue the wireless connection. I am fairly sure it is hooked up properly, but no wired connection comes up under networks. So, hope you can assist, thanks for listening, psongman
    03-09-2018 04:59 PM
  2. dpw09's Avatar
    Are you sure it's 2nd gen? 1st gen doesn't have option. Does your remote have the Alexa mic button? Gen1 doesn't have that either.
    01-03-2019 08:27 PM
  1. Exchange using up battery - what is this?
    By sethm1 in forum LG V30
    Last Post: 06-04-2018, 10:20 AM
  2. how to connect a usb key to my samsung a5
    Last Post: 03-10-2018, 03:34 PM
  3. I don't get notification on my Samsung emerge phone
    Last Post: 03-10-2018, 03:11 AM
  4. how can i get the voicemail icon on my galaxy 8 to show number of messages?
    Last Post: 03-09-2018, 03:40 PM
  5. how do I unlock my phone
    Last Post: 03-09-2018, 12:47 PM
