1. edgie70's Avatar
    Hi all , I have a gen 2 fire box , my router is about 13 feet away and I'm using the 5ghz frequency but in the dev opt of my box it says WiFi strength is only about 50% also I have approx 32mbps download when checking on my phone but approx 4 on the box ... anyone know anything about this ??
    04-21-2020 05:19 AM
  2. edgie70's Avatar
    Haha what dya mean it looks like a good one ?
    04-21-2020 06:09 AM
  3. Kizzy Catwoman's Avatar
    Have you tried to restart the router and the fire tv box by switching them off and on again? Sometimes this can sort out WiFi problems.
    DARK Vader777 likes this.
    04-21-2020 06:10 AM
  4. Rowlette's Avatar
    I would add a little hardware to eliminate the WiFi by using Ethernet adapter then you have options from the cheapest solution 20 ft CAT cable to best MoCA connection.
    04-21-2020 07:05 AM
  5. edgie70's Avatar
    Yeah I restarted them both , signal went up but then went back to the orange ( green is good signal orange ok red bad )
    04-21-2020 07:10 AM
  6. DARK Vader777's Avatar
    Go into app manager and clear cache on all apps that you can.
    Restart Router and Firestick the same time.
    The Ethernet adapter will not make a big difference.
    I see you're running under 5 down? You need to either ramp up your speed from your carrier if you can afford it.
    If you're watching 1080p movies, you need all the bandwidth you can get.
    You running other things off the Same network. This is another reason to ramp up speeds.
    05-20-2020 04:27 PM
  1. my new phone is losing wifi connection all the time.
    By vistascape in forum General Help and How To
    Last Post: 04-23-2020, 06:49 PM
  2. Android TV box safe ?
    By edgie70 in forum Android TV
    Last Post: 04-21-2020, 08:40 AM
  3. I have a zte 3351s, how do i mirror it to my apple tv 4k please help
    By deon carter in forum General Help and How To
    Last Post: 04-20-2020, 01:32 PM
  4. ZenPad 8 won't connect to WiFi
    By thyde76 in forum ASUS ZenPad 8.0
    Last Post: 04-19-2020, 03:35 PM
  5. Replies: 1
    Last Post: 04-19-2020, 08:23 AM
