New Samsung alert! Score a Galaxy S21 5G for as little as $99 right now
Touchscreen Issues While Charging
- Ok so I have searched Google and the local AC forums and can't find an answer to this, but I have been playing with my wife's Fire that I got her for Christmas and noticed while charging the touchscreen is acting rather screwy.
For instance, barely tapping the screen will register as a double tap. So if I were to open the settings menu by tapping the top right corner, the settings will open and instantly close again as though I tapped it twice.
or when trying to play Angry Birds, pressing on the screen and dragging to the left to view the setup the pigs are in results in a pinch to zoom gesture and zooms out all the way. When I try to slingshot a bird they drop right in front of the slingshot as though I released the bird without pulling back.
Scrolling in webpages and menues results in either the pressing of a link and no page movement or a zoom out or in.
Is anyone else having or heard of someone having this issue?
I'm not rooted and I'm running stock 6.2.1
Thanks01-11-2012 10:57 PMLike 0 - I'm surprised that you weren't able to come across anything. I've had three Android smartphones prior to the Kindle Fire, and I'm a veteran of other Android forums - thus was an issue with the smartphones as well. Screwy things are known to happen on occasion when you use the device while it's plugged into a charger.
I once picked up an Android phone while it was plugged in and it activated an app-locking security app that I hadn't used in 6 months (good thing I remembered the password I had used). I haven't had an issue yet with the Fire, but if it did start happening it wouldn't surprise me.
It's especially pronounced when using a non-oem charger.
Sent from my Kindle Fire using Tapatalk01-11-2012 11:58 PMLike 0 - I'm surprised that you weren't able to come across anything. I've had three Android smartphones prior to the Kindle Fire, and I'm a veteran of other Android forums - thus was an issue with the smartphones as well. Screwy things are known to happen on occasion when you use the device while it's plugged into a charger.
If it is a common issue I could probably deal with it, but if it is a device specific problem I will exchange it for a different/new one.
After initially receiving my Fire I had another screen problem where a single pixel wide yellow line appeared about a third of the way up the screen in portrait that ran the full width of the screen and I'm wondering if the two issues may be in some way related.01-12-2012 12:41 AMLike 0 - I'm so glad I found this... I just got my Kindle Fire HD and I noticed that it was screwy when I tired to use it the first time. Then it went away and at first I wasn't sure what the issue was. It was happening off and on,
I now realize it was happening very time I was trying to use it while charging. So thank you, I almost sent the thing back.
08-01-2013 11:59 PMLike 0
- Forum
- More Android Goodness
- The Archives
- Android Central Archives
- Amazon
- Amazon Kindle Fire
