1. Carballoca's Avatar
    I noticed today that when I plugged my kindle fire into the charger nothing is happening checked everything and nothing. I just bought this in Nov so is it the charger or the kindle I never have liked that sloppiness of how loose the charger fit into the USB port anybody else have this problem what ever it is it should be covered me the warranty it`s not that old to be having things go wrong with it already...
    07-19-2012 09:14 PM
  2. Little Darwin's Avatar
    I had some strangeness with the charging a while back, and I shut the Fire off and turned it back on, which fixed my issue. I have several micro-usb chargers, and none of them worked before the reboot.
    07-20-2012 11:18 AM
  3. mkiker2089's Avatar
    I think it's software as well. A ten second hard reboot may help.
    07-20-2012 07:14 PM
