07-06-2018 04:35 PM
78 ... 234
tools
  1. hallux's Avatar
    @dariotto The files that show as inaccessible are the Android system files, you can't do anything about those.
    07-05-2018 08:51 AM
  2. B. Diddy's Avatar
    @dariotto, how many apps have you installed? Show us a screenshot of your Settings>Storage menu. You might also want to us DiskUsage to get a better idea of what's taking up storage.
    07-06-2018 03:58 PM
  3. B. Diddy's Avatar
    I have an odd situation:
    I have a Samsung S4mini running 4.2.2
    Under device memory it says that my total space is 8GB, my available space is 276MB, and that my applications take up 96.94GB !
    My SD card has 12.15GB free out of 29.71GB.
    How do I fix this? I already deleted most of my apps.
    I can't update or install any apps or even properly sign in to my google account.
    Welcome to Android Central! Try wiping the cache partition: https://support.t-mobile.com/docs/DOC-27777
    07-06-2018 04:35 PM
78 ... 234
  1. Replies: 1
    Last Post: 11-21-2016, 10:51 PM
  2. Replies: 1
    Last Post: 11-21-2016, 09:53 PM
  3. just out of nowhere my galaxy s3 refuses to stay on
    By StartrekAnubus in forum Samsung Galaxy S3 Rooting, ROMs, & Hacks
    Last Post: 11-21-2016, 09:50 PM
  4. Is it possible to unlock a sprint note 4
    Last Post: 11-21-2016, 09:37 PM
