1. Paul Guest1's Avatar
    I'm running the Q beta on a Pixel 3a XL and I notice that battery life is not very good at all: for example, this morning my wife took the 3a XL off the charger, at 100%, at 6 am and ended up leaving it on the table, doing nothing. By noon, it was down to 52%. That's obviously kind of terrible but I chalk it up to using beta software.
    06-27-2019 12:39 PM
  2. B. Diddy's Avatar
    Sounds like more of a Q Beta issue. Would you like me to move this to the Android Q forum instead?
    06-27-2019 02:17 PM
  3. Paul Guest1's Avatar
    Oh, if you like. I assume it's a Q beta issue. As for the phone, I think it's pretty great.
    06-27-2019 02:45 PM
  4. mogelijk's Avatar
    You might report this to the Android Q beta team, make sure they are aware of the issue.
    06-28-2019 08:49 AM
  5. eric002's Avatar
    Exactly! Furthermore so though, I will say that ever since I've been on Q beta platform, my 3 XL has gotten excellent battery life. I'd suggest trying to wipe the phone once or opt out of the beta and rejoin possibly.
    06-28-2019 02:00 PM
  6. Paul Guest1's Avatar
    I opted out and the battery life is fine. Of course, it could be the wipe that did it. I think I will wait and see before trying it again.
    06-28-2019 02:23 PM
  7. eric002's Avatar
    Honestly, if you already opted out of the beta, I would try once more to re-enroll and see if that was it. Honestly, my Android Q beta has always had incredible battery life.
    anon(10092459) likes this.
    06-28-2019 02:36 PM
  8. anon(10092459)'s Avatar
    The idle time has been great for me on DP 4my Pixel 2.
    Attached Thumbnails Battery life not great-screenshot_20190629-092936.jpg   Battery life not great-screenshot_20190629-093000.jpg
    eric002 likes this.
    06-29-2019 11:34 AM
  9. cbreze's Avatar
    Battery life on my pixel 2 is the best it has ever been. I think Q is very battery friendly, no complaints from me.
    eric002, anon(10092459) and mbxx like this.
    06-29-2019 12:06 PM
  10. richard hemenway's Avatar
    Is NFC turned off ,
    07-02-2019 12:52 PM
  11. Harp Silver's Avatar
    Battery life on my Pixel 3XL has gone through the roof it's lasting three days on one charge loving Android Q so far
    07-02-2019 01:32 PM
  12. Chaz Chavers's Avatar
    Been running the Q beta since Beta 1 and I will say that it has gotten better with each iteration. Can easily go about 11 hours in between charges. I don't care what Google says, I feel like Digital Wellbeing is a battery life assassin! Since I've turned it off I've been able to squeeze out more screen time.
    07-02-2019 04:41 PM
  13. eric002's Avatar
    interesting, I mean I never thought of digit will be as a bad or a life assassin! I think I still have accessibility for that turns off though. Android Q is amazing on bad or I'm getting 11 12 hours per charge. However, since Android Auto in the car I charge off via USB all the time. I use about 40 to 45% of my battery and reading day.
    07-02-2019 05:06 PM
  14. Paul Guest1's Avatar
    Yes, NFC is turned off.
    07-03-2019 08:57 AM
  15. Nick Dansie's Avatar
    Same! I have the Pixel 2 xl and it has been better then ever! Used to last the day fine with like 20% at the end of the day but now it lasts till about 40% at the end of the day!
    eric002 likes this.
    07-03-2019 11:56 AM
  16. mcdonsco's Avatar
    Anyone running it on a pixel 3 and have a gear S3? Everytime I've tried it drains my watch battery in a couple hours (literally full to empty in like 2-3 hours).
    Is this still a problem?
    07-03-2019 12:12 PM
  17. Lavin Williams's Avatar
    I'm running the beta on my 2xl and so far I have to say I'm getting pretty battery life, it last me all day and that running Bluetooth to my watch and earbud listening podcast and music, and playing games while on my breaks through out my day. And when I'm off work I'm looking at YouTube until 10 to 11 pm with about 20 to 30 percent before going to bed
    07-03-2019 04:05 PM
  18. Kizzy Catwoman's Avatar
    Battery life on my Pixel 2 XL has been excellent since being on Q and beta 4 it has been even better. Much better battery life than on Pie.
    07-05-2019 03:54 PM
  19. Dachillefx's Avatar
    On Android VIP or as you would call it Pie my battery usage would read 1day and 10-12 hrs before empty. Now on Q beta, I've been getting reading that says 23hrs and at the very most 1day and 2 hrs. So for me, the battery life is sucking it up. Hopefully, this will get better. Meanwhile, I'll be awaiting the Beast phone...Pixel 4XL.
    08-18-2019 10:48 AM
  20. rexxsor's Avatar
    Running Q beta 6. Battery life about the same as Pie.
    Using a Pixel 3 with around 3-4 hours SoT (can reach 5 hours when using WiFi). Admittedly very heavy user here (games, music via Bluetooth, browsing social media).
    08-19-2019 11:06 PM
  21. eric002's Avatar
    Android Q beta 6 with the Google Play services beta version my battery life is great!
    08-20-2019 05:54 AM
  22. rexxsor's Avatar
    Is the Google Play services beta version separate from the Q beta 6? How do I get it?
    08-20-2019 12:49 PM
  23. eric002's Avatar
    Yes, yes indeed it is. Try checking this web Page out: https://lifehacker.com/how-to-fix-th...r-b-1837170436
    08-20-2019 02:14 PM
  24. rexxsor's Avatar
    Will check it out, thanks!
    I did a quick peek at my Play Services version and seems to be a newer one already (version 18.3.85). Which one is yours currently?
    08-20-2019 07:02 PM
  25. eric002's Avatar
    So hell yeah dude, no problem whatsoever Check out my version...
    rexxsor likes this.
    08-20-2019 07:17 PM
  1. Infinix x554 off(& not charging) but detected on usb.
    By Alex keronei in forum Ask a Question
    Last Post: 06-28-2019, 02:28 PM
  2. Do Not Disturb does NOT work
    By Abbers727 in forum Samsung Galaxy S9 & S9+
    Last Post: 06-28-2019, 08:27 AM
  3. Drone jjrc x8 not connecting to phone
    Last Post: 06-27-2019, 12:14 PM
  4. Galaxy Active Watch not tracking sleep
    By Android Central Question in forum Samsung Galaxy Watch Active
    Last Post: 06-27-2019, 08:39 AM
  5. Galaxy Active Watch not tracking sleep
    Last Post: 06-27-2019, 07:47 AM
