1. eric002's Avatar
    So last week I tested turning off digital being on my Pixel 3 XL. Just wanted to share something else with you: usually during the weekend I have to charge my phone a little bit since I'm not committing to work therefore I'm not in the car with Android Auto and USB charging as long. I barely put my phone on the charger for more than a couple minutes on Saturday and Sunday. I'm mostly just charged up in the car my phone went down to 30% last night charges it up to work this morning and then a little off my laptop and it's fine. The rate at which it discharges now is really slow and in charge of just as fast. So far, I'm really shocked by the results!
    01-27-2020 11:28 AM
  2. Rukbat's Avatar
    How do you "turn off digital"? The whole phone is digital. Did you mean "turn off the phone"? Or "turn off the GPS"? Or "turn off Bluetooth"? Or what?
    By the way, start charging at 50%-45%. Letting the battery get down to 30% shortens its life.
    01-27-2020 06:26 PM
  3. eric002's Avatar
    I usually don't go below 50 60% during the day one I start charging you back up. Here's what I mean by turning off access to digital well-being
    01-27-2020 06:31 PM
  4. Javier P's Avatar
    I think the OP is referring to Google Digital Wellbeing, which some people have reported as a cause for battery drain.
    01-27-2020 06:32 PM
  5. eric002's Avatar
    Yeah that's what I thought this was. If not I apologize. I know that sometimes visual being was causing battery drain issues for people that's why....
    Javier P likes this.
    01-27-2020 06:33 PM
  6. Rukbat's Avatar
    Oh, if that's the case, I can understand it. Its full name should be "Digital Wellbeing For Samsung's Battery Department's Bottom Line".
    01-27-2020 06:34 PM
  7. eric002's Avatar
    Hahaha yeah, so far I'm on my battery life with these small few changes is amazing!
    01-27-2020 06:37 PM
  8. Javier P's Avatar
    Yes, I've seen many reports saying the same thing. I tried to disable that feature on day one.
    eric002 likes this.
    01-27-2020 06:41 PM
  9. eric002's Avatar
    Honestly, never even thought of disabling the feature turning off user access off.. however, once I did even my moderate battery usage increase. I'm still shocked.
    01-27-2020 06:42 PM
  10. mustang7757's Avatar
    I don't use that feature and it's off
    01-27-2020 07:05 PM
  11. eric002's Avatar
    It is off for me now as well! Lol
    01-27-2020 07:18 PM
  12. mustang7757's Avatar
    01-27-2020 07:25 PM
  13. eric002's Avatar
    01-27-2020 07:26 PM
  14. ralfyguy's Avatar
    How did you turn it off?
    01-27-2020 07:40 PM
  15. mustang7757's Avatar
    Go into the app 3 dots upper right corner turn off usage
    eric002 likes this.
    01-27-2020 07:49 PM
  16. ralfyguy's Avatar
    That option is not there.
    01-29-2020 10:29 PM
  17. mustang7757's Avatar
    Screenshot:Improved battery-screenshot_20200129-224105-2.jpeg
    eric002 likes this.
    01-29-2020 10:43 PM
  18. Xxwabbit's Avatar
    I'm not seeing it. When I tap the app icon, then the 3dots, only 2 options come up: hide app icon and about digital wellbeing.
    01-30-2020 08:33 AM
  19. eric002's Avatar
    I'm not seeing it. When I tap the app icon, then the 3dots, only 2 options come up: hide app icon and about digital wellbeing. [IMG=135x285]https://uploads.tapatalk-cdn.com/20200130/1b4d78af06e808527b27bb38f3a79927.jpg[/url]
    [IMG=270x570]https://uploads.tapatalk-cdn.com/20200130/a89e166f9d78c3ab9310b80878f4f3c1.jpg[/url]
    Go to settings, digital well-being, and then click on the 3 dots. You should see it there.
    01-30-2020 08:53 AM
  20. Javier P's Avatar
    As Eric said, go to settings and scroll down until you find Digital Wellbeing. In some phones this option could be placed in a different section, in that case open settings, tap the search bar (magnifying glass), type "digital" and the option should appear.
    Improved battery-screenshot_20200130-105542.jpegImproved battery-screenshot_20200130-105524.jpeg
    01-30-2020 09:02 AM
  21. mustang7757's Avatar
    @Xxwabbit
    On Samsung its different , you cant go to the 3 dots , go to app list clear data ,cache and force close it digital wellbeing and when you go back in it dont touch any of the screen to activate it should look like this Improved battery-screenshot_20200130-112753_digital-20wellbeing-20and-20parental-20controls.jpeg
    01-30-2020 11:29 AM
  22. mustang7757's Avatar
    Also I have its app data access off in settings>apps>3 dots upper rightcorner tap > special access tap> scroll down to data access tap and turn off Improved battery-screenshot_20200130-113943_settings.jpeg
    Xxwabbit likes this.
    01-30-2020 11:41 AM
  23. Xxwabbit's Avatar
    Fixed thanks to you.
    mustang7757 and eric002 like this.
    01-30-2020 10:19 PM
  24. mustang7757's Avatar
    Your welcome
    eric002 likes this.
    01-30-2020 10:22 PM
  1. My battery is draining too fast
    By jasmain in forum Samsung Galaxy Note 5
    Last Post: 02-06-2020, 02:59 PM
  2. Sudden rapid battery drops
    By Johnston212 in forum Samsung Galaxy Note 9
    Last Post: 01-31-2020, 06:22 AM
  3. Battery level spikes and phone shuts down after latest update
    By rcpa in forum Google Pixel 4 & Pixel 4 XL
    Last Post: 01-27-2020, 08:08 AM
  4. charger not charging battery
    Last Post: 01-26-2020, 08:42 PM
  5. Why is my battery down
    Last Post: 01-24-2020, 09:57 AM
