Originally Posted by
mustang7757 Nothing stands out there
Why do you think the drain is in WiFi not mobile data? You on WiFi mostly?
What does battery stats say under battery?
Google Play Services seems to be the biggest user of battery, but I've completely disabled all Google applications and it still persists. I'm just going to have to try a factory reset, if not more. This was an "open box" phone, but I'm positive this is a software issue since this does not happen on data when wifi if off. I did spend close to 6 hours updating the phone; update by update (sorry, can't remember the terminology for that).
