09-10-2022 11:09 PM
30 12
tools
  1. Garrett190286's Avatar
    LG Velvet, Android 11, I've exhausted all background data and wifi useage settings I could find. When wifi is on there is a continuos wifi usage causing a battery drain. I've used an app to detect what apps are using wifi and how much wifi they are using. The culprit appears to be "the android" symbol and "tethering." My tethering is off and all tethering settings have been checked. This happens when the screen is locked or unlocked. Any thoughts on what this continuos wifi usage can be? I've attached a screen shot from the wifi usage monitoring app.
    Attached Thumbnails Unknown (sort of) Android 11/LG Velvet Wifi Battery Drain-305364784_497327652225132_782811039503383465_n.jpg
    09-10-2022 06:15 PM
  2. mustang7757's Avatar
    I took care your other post
    Welcome to AC!
    09-10-2022 06:27 PM
  3. mustang7757's Avatar
    You using your device as usb tethering?
    09-10-2022 06:31 PM
  4. Garrett190286's Avatar
    Thank you! No USB tethering. All settings off for Wifi and USB tethering.
    mustang7757 likes this.
    09-10-2022 06:42 PM
  5. mustang7757's Avatar
    Try going to settings >apps>find tethering and tap , clear uts data then force stop it
    Laura Knotek likes this.
    09-10-2022 06:44 PM
  6. Garrett190286's Avatar
    No option to force stop tethering. Tethering permission is Phone and unable to deny. Can't clear data or cache. Other apps included in tethering usage is Cell Broadcast Service, Network Manager, com.android.server.NetworkPermissionConfig. Background restrictions in place, not excluded from power saving exclusions.
    09-10-2022 07:39 PM
  7. Garrett190286's Avatar
    Clear data and clear cache are grayed out. Still no option to force stop tethering.
    09-10-2022 08:04 PM
  8. B. Diddy's Avatar
    Welcome to Android Central! Does it also happen in Safe Mode? https://www.hardreset.info/devices/l...-5g/safe-mode/
    09-10-2022 09:52 PM
  9. mustang7757's Avatar
    Interesting
    This one going be little tricky
    Try what b. Diddy suggest.
    09-10-2022 09:56 PM
  10. Garrett190286's Avatar
    Interesting
    So weird. Safe made activated and I'm still seeing wifi continuosly sending and recieving! I may have to try resetting the phone.
    09-10-2022 10:03 PM
  11. mustang7757's Avatar
    I think you might be right a factory reset may be in order
    09-10-2022 10:04 PM
  12. Garrett190286's Avatar
    Then again. I think this only happens on my home network. My battery didn't seem to drain at work on the wifi network. Figured this could be useful information!
    09-10-2022 10:07 PM
  13. B. Diddy's Avatar
    Ok, try rebooting your router by unplugging its power for about 30 seconds.
    09-10-2022 10:09 PM
  14. mustang7757's Avatar
    Another to check go to setting>connection>Mobile data usage >should have WiFi usage there see what the default system is saying instead of 3rd party ?
    09-10-2022 10:10 PM
  15. Garrett190286's Avatar
    Not quite sure I can find this. Would this be the wifi network the phone is connected to?
    09-10-2022 10:30 PM
  16. Garrett190286's Avatar
    I can find the wifi usage under the mobile data settings. Shows greatest usage to least.
    09-10-2022 10:31 PM
  17. mustang7757's Avatar
    Ok can you show screenshot of that maybe?
    09-10-2022 10:32 PM
  18. Garrett190286's Avatar
    Unknown (sort of) Android 11/LG Velvet Wifi Battery Drain-1.jpg
    09-10-2022 10:35 PM
  19. Garrett190286's Avatar
    09-10-2022 10:36 PM
  20. mustang7757's Avatar
    Tap on WiFi think it's mobile data at the bottom
    09-10-2022 10:36 PM
  21. Garrett190286's Avatar
    Yep! Wifi not working currently. Coming. lol
    09-10-2022 10:39 PM
  22. Garrett190286's Avatar
    09-10-2022 10:40 PM
  23. Garrett190286's Avatar
    09-10-2022 10:41 PM
  24. Garrett190286's Avatar
    09-10-2022 10:43 PM
  25. Garrett190286's Avatar
    09-10-2022 10:43 PM
30 12
  1. Android 11 help please.
    By Lordladeda in forum Android 11
    Last Post: 09-12-2022, 02:36 PM
  2. Android auto ,on Huawei p40 pro
    By andy1494 in forum Huawei P40
    Last Post: 09-12-2022, 11:42 AM
  3. On Moto g stylus 5g how do I get rid of mobile installer, or is it a boost thing?
    Last Post: 09-10-2022, 09:58 PM
  4. Android 11 help please.
    Last Post: 09-10-2022, 06:37 AM
