Originally Posted by
Sandman333 I've restarted the phone a dozen times. It doesn't change the menu options
It's a Verizon branded phone.
BTW, the Android Central app is broken. You can start a new thread, but it won't let you reply to one. You can touch the field where your reply goes, but it will not let you type anything. The Chrome web interface on my phone is also broken for AC- there is no login option anywhere. The only way I was able to reply here is through the Tapatalk app. What is going on with AC?
Sent from my SM-G998U using Tapatalk
AC forum apps is working on my end might want try reset it by clearing Data then force stop it , as for log back in on chrome tap create account once it takes you to that page at the bottom should say if already a member log in for some reason they changed it to that section and we reported to Admin to see we can get it back .
When you place a call does it say at the top of the dialer page HD calling? I think it possible they took those functions out to enable/disable
