Hi, I've been using Call Recorder by Skvalex ver. 3.5.3 (that one you don't find in PlayStore but in the developer's website) for a few years. My phone is a no rooted Oneplus 7 Pro (build: GM1913_11_H.30) and I remember that when I upgraded to Android 11 I started to get some issues that were quickly fixed by the developer.
However, it looks like that with newer Android versions (I'm using Android 12 which is quite light in regards to the draining of battery) new issues are occuring like:
- sometimes (almost 50% of the time) the recordings don't start automatically and I need to switch the key recorder in the dialer manually. However, sometimes the key recorder is not available (doesn't appear) but only the Contacts key;
- the recordings start time is wrong and it is anticipated of the time of the lasted call than real start time of call (i.e.: I call at 14,00 someone for 20 mins and my recording start call will be 13,40);
- the Sign in to Google Drive for uploading recordings must be done periodically;
- near the max peak sound distorts:
- the speed control recording play is ineffective.
Hoping to open a useful thread it would be interesting to know your possible good experience with either this app or others from the Android 12 version or higher with no rooted phones.
12-13-2022 05:28 AM
