Hi All
I have an sumsung galaxy nexus.
I usually listen to music or use a gps program while I'm riding my bike , I want to silence or forward incoming calls to voicemail during the ride, I prefer a toggle widget.
what I found is 'call block' which works ok. what I'm missing is that the blocked list only shows the caller number but not her name from my contacts list. and that there is no indication in the status bar that the app is running , this indication is important so I remember to turn off when I'm not riding.
I will appreciate any suggestions or other apps I can use.
Thank you
Thank you
