1. Jarvishotmail's Avatar
    I'm using SE XPERIA ARC S.
    I upgraded my mobile to ICS and I installed IGORs FASTNOTEPAD, which I used to take notes and it was working fine... When my mobile has an issue I re-installed the ICS and the FastNotepad... When I restore the saved files from SD Card it shows.... #decrypt error..... As I have all my imp notes from my class and payment details I'm unable to access.. I msgd to IGORs site no use.. Can anyone help... Thanq
    10-24-2013 07:24 AM
  2. nurmia's Avatar
    i don't know it correctly.i will know you latter.
    11-12-2013 11:37 PM
  1. Quick question ..... some help as well.
    By sinkist77 in forum General Help and How To
    Last Post: 12-01-2013, 09:35 PM
  2. plz help me know what happend
    By lalylaylow in forum General Help and How To
    Last Post: 10-25-2013, 10:24 PM
  3. HELP GS4 keeps vibrating in my ear.
    By usafracer in forum AT&T Samsung Galaxy S4
    Last Post: 10-23-2013, 09:57 PM
  4. HELP ASAP! Suddenly NO SD CARD Found! Tried Everything...
    By Kris Garvey in forum Samsung Galaxy Note 2
    Last Post: 10-23-2013, 09:41 PM
  5. Need help with VoIP Apps Crashing
    By Nurega21 in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 10-23-2013, 08:16 PM
