1. got_dibz's Avatar
    Hi everybody,
    My phone doesnt seem like it wants to ugrade..when going into settings software update, no updates r available..i do not have the latest update (checked) and i think it went to factory mode last time i formatted it...what can i do? Thx
    Sent from my GT-I9300 using Android Central Forums
    05-23-2013 01:06 PM
  2. patruns's Avatar
    Either Samsung or your carrier has not decided to update at this point.
    05-23-2013 01:43 PM
  3. srkmagnus's Avatar
    Device updates that are sent OTA (over the air) are often sent in "waves". Meaning, not all devices will receive the update at the same time and it could take weeks to reach your device. Check the forum for your device and see if there is a way to manually update: http://forums.androidcentral.com/samsung-galaxy-s3/
    Also, check with Samsung's desktop client, Kies, for the update. The OTA might take time to reach your device, and often, the update is made available through Kies with no waiting.
    05-25-2013 12:46 AM
  4. Golfdriver97's Avatar
    Hi everybody,
    A Galaxy S3 variant? Are you wondering about the 4.2 update? If yes to both, 4.2 generally comes out on the international versions first, then the US versions. As of right now, they are testing the 4.2 International (there are leaks seen here and there) but nothing more.
    05-26-2013 12:15 AM
  5. got_dibz's Avatar
    Hi all and thablnks for the replies.
    My current version is 4.0.4 which i think is an outdated upgrade but doest want to upgrade to jelly bean which (i guess) is the 4.1.1 update. Tried almost everythng from downloading hotfile from samsung update to clearing google framework servicea but it still isnt finding any updates. Could it be blocked in some way from receiving any files? What else can i do to try to make it work? Thx
    06-07-2013 12:26 PM
  6. got_dibz's Avatar
    Should i just reformat it once more and give it a shot? Might as well since i dnt have any important stuff since my last virus struck. What do u think?
    06-07-2013 12:29 PM
  7. mautwt's Avatar
    06-09-2013 02:43 PM
  8. got_dibz's Avatar
    Hi everyone..
    Ok forget trying to upgrade to 4.2.2 what if i just want the newest upgrade available? How can i upgrade to tht? I still dnt understand why my phone refuses to upgrade .. should i reset my device?
    Sent from my GT-I9300 using AC Forums mobile app
    07-21-2013 04:19 PM
  9. got_dibz's Avatar
    How can i go around using my on board automatic upgradr? Can i download the upgrade on my pc and transfer it onto my phone?
    07-21-2013 04:20 PM
  1. 2.3 Upgrade Problems
    By chaddley in forum Verizon HTC Thunderbolt
    Last Post: 09-29-2011, 09:29 AM
  2. Kindle App upgrade problem
    By artcwolf in forum Barnes & Noble Nook Color
    Last Post: 05-19-2011, 08:15 PM
  3. Droid X and upgrade problem
    By av8solo101 in forum Motorola Droid X
    Last Post: 07-16-2010, 09:15 AM
  4. Anyone else having MASSIVE upgrade problems?
    By Grebnehtor in forum Sprint
    Last Post: 06-23-2010, 11:52 PM
  5. Anyone else having MASSIVE upgrade problems?
    By sixtyin3 in forum HTC EVO 4G
    Last Post: 06-22-2010, 04:31 PM
