01-29-2019 11:35 AM
31 12
tools
  1. pasha0's Avatar
    Hello, my phone (lenovo a369i) was stuck on the lenovo logo and nothing was happening so I wanted to flash my phone and downloaded the smart phone flash software and launched it. Then I followed all steps and I clicked the download button within the software after some time there was some power issue with my PC so the process was not completed. After that when I tried to open my mobile it was not opening and even the lenovo brand was not displaying now but was displaying before.
    I think this is due to the incomplete process which killed my phone. So now my mobile is not opening and not showing the lenovo logo also are there any chances to repair my mobile.
    04-03-2016 11:50 AM
  2. Samanthajanelle87's Avatar
    I was given an Android phone from my cousin that he said he had tried to flash it and used the wrong software and now the phone will not come on at all...is it fixable? If so how?
    08-03-2016 07:38 AM
  3. software helper's Avatar
    hi , can you help me get ride off problem
    i had rooted my karbonn s5 n it successfull rooted that ok
    after that i had installed various apps
    superuser, cleaner etc,
    and i also installed "chainfire 3d" and i had give permission to superuser to root access
    and again i had given the permission to chainfire 3d to root access
    then my phone gone to booting
    for 1 to 2 minutes
    and i taken out battery
    and kept again
    now the phone is not opening ie only showing booting screen
    please help me
    my phone model is karbonn titanium s5 andriod version 4.1.0 jelly bean
    pls help me i bought it just 5 months before
    pls help me
    Its very simple get to a pc and flash a new rom either custom or stock and flash it with your phone model's usb driver but if you had not backuped your data then there is no way to recover i just soft bricked my phone but i flashed a rom and my phone get started
    07-26-2017 01:09 AM
  4. daniel ingham1's Avatar
    A dirty flash is when you already flashed a ROM, let's say Cyanogenmod 11 (KitKat), and then without doing a data/factory reset in the recovery, you flash a newer ROM on it (let's say Cyanogenmod 12 (Lolipop)). SOMETIMES this can work, but 95% of the time it won't without glitches.
    This won't kill your device, merely a chance for a softbrick. When that happens, you just go to the bootloader > recovery and then data/factory reset, and you install the newer ROM.
    You will lose your apps and data, though, that's why some people try a dirty flash first.
    I did a dirty flash on my phone and it hard-bricked it, not soft-bricked.
    08-02-2017 10:35 AM
  5. MrBlaXD's Avatar
    guys i was trying to do a backup in CWM recovery and then i reset my galaxy core to factory settings then it was stucked in CWM menu and now when i start my cell thr is a yello logo triangle whatever u call it and then my cell goes to recovery option what should i do ihve tried factory reset.....but problem is still there my phone is in recovery menu is this is a hard brick please help....!!
    I face this problem too, I try to uninstall Xposed Firmware but It boot me in to Recovery mode (I use TWRP). When I try to reboot again, It always boot me in to recovery mode.
    But i can fixed, I flash rom with official firmware that change Custom Recovery to Official Recovery. Thats mean, You device is only soft-brick not Hard-brick.
    11-17-2018 11:59 PM
  6. Flam3Wo1f's Avatar
    Someone help me I tryed rooting my Samsung galaxy tab 4 and it worked but a bunch of stuff kept popping up like "unfortunately ... has stopped working" so I shut it down and turn it on and it froze on the startup screen is it bricked??
    01-29-2019 11:35 AM
31 12
  1. Can I buy the Play version and jump ship to another carrier?
    By mbfavreau in forum HTC One Google Edition
    Last Post: 08-06-2013, 09:07 PM
  2. Latest AT&T software update "bricked" my phone
    By redsoxsurfer in forum AT&T HTC One
    Last Post: 08-05-2013, 08:12 PM
  3. Duplicate and triplcate texts
    By PaulaO in forum Sprint Galaxy S III
    Last Post: 08-05-2013, 02:32 PM
  4. Screen panicking and becoming uncontrollable
    By xHylian in forum Samsung Galaxy S3
    Last Post: 08-04-2013, 11:22 PM
  5. HTC One bricked, may be able to rescue but need help
    By Pacino24 in forum HTC One Rooting, ROMs & Hacks
    Last Post: 08-04-2013, 07:32 PM
