1. srmoska's Avatar
    A couple weeks ago an Alcatel one touch s'pop (4030a) and a couple days ago i was at night traveling on a taxi when i wanted to take a picture when i tried to use the camera i noticed the screen was black. the camera wasn't working then when i was waving the camera around to see if i was able to see anything the camera started working when i looked directly at the ceiling light. I have been experimenting with the camera and it happens everytime when the light conditions are low. But if i get it able to start working for examplem like when turning on the room light and then turn it off. The camera keeps working and it can even see the led lights of some of my devices like the tv and such. Is there some way to fix this? Thanks for any help in advance
    09-13-2013 01:03 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Cameras on Android phones are generally not great with low light, so are you sure it's not functioning, or is it just unable to gather enough light until you point it at a lamp?
    09-13-2013 02:36 AM
  3. srmoska's Avatar
    It works fine on daylight and well lit rooms, but on low light conditions it stays like turned off untill it detects a bright light.
    What bothers me is that when there is very low light It won't activate
    If you turn it on on a well lit room at night then turn off the lights it keeps working as you can see things like standby leds on tv's and gameconsoles. but if you try to use the camera with the lighst off it dosen't evenb try to show anything.I want to know if there's a way to bypass this issue
    09-13-2013 10:31 AM
  1. Adding school email to gmail app (with advanced options)
    By HulaHoop13 in forum Samsung Galaxy S4
    Last Post: 12-03-2015, 05:01 PM
  2. How to completely disable mobile data from being turned on?
    By xD4rk in forum T-Mobile Samsung Galaxy S4
    Last Post: 06-19-2015, 02:15 AM
  3. help with viewing text
    By difranco90 in forum HTC One M7
    Last Post: 09-16-2013, 07:08 AM
  4. problems with default PDF reader
    By jcc52590 in forum General Help and How To
    Last Post: 09-14-2013, 03:28 PM
  5. voice and data on verizon
    By ericizzy1 in forum Moto X (2013)
    Last Post: 09-12-2013, 09:54 PM
