1. ollwien's Avatar
    Hi, I am an amateur about this. Basically I rooted my phone when it was 4.2.2. Then I updated the phone officially (directly from the phone option) to 4.3. The superuser is still installed on the phone. I want to remove the root (maybe has been removed by the update) and the superuser, making it like factory default. I have tried factory default reset but the superuser is still there. I am using nexus 4. Please help me and tell me in steps. I am a total amateur. Thanks for your help. I really appreciate any help. Thanks again
    10-22-2013 07:46 AM
  2. Paul627g's Avatar
    Your best option would be to grab the official Factory Images from Google for the Nexus 4 and flash the device to 4.3. This will reset everything and remove root, leave it completely stock.
    As far as saving your important information, you can grab Helium from the Play Store and use that to save any important apps & related data. Contacts/Calendar and other options can be sync'd thru your Settings to your Google account.
    https://developers.google.com/androi...hl=fr-FR#occam
    10-22-2013 08:23 AM
  1. Verizon LG G2 - Upgrade to EDGE Plan or Buy Retail?
    By fredhoffmann3 in forum Verizon LG G2
    Last Post: 10-24-2013, 07:26 PM
  2. Verizon Galaxy Note 2 - battery monitor help
    By Jonathan Rodriguez3 in forum Verizon Galaxy Note 2
    Last Post: 10-24-2013, 11:59 AM
  3. Help Upgrading LG Lucid 2 VS870 to Android 4.2.2
    By Kevin Colwell in forum General Help and How To
    Last Post: 10-23-2013, 10:21 PM
  4. BBM To Nexus 7
    By seamonky in forum Google Nexus 7 Tablet (2013)
    Last Post: 10-22-2013, 03:13 PM
  5. Facebook wont Connect to Apps and Games
    By watts320 in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 10-22-2013, 07:36 AM
