1. Aryeo's Avatar
    I woke up, my phone was at 100% charge. I turned it on to check email/facebook, etc and suddenly noticed that the battery had dropped to 50%. The battery breakdown menu shows that it dropped almost instantly, 82% thanks to my screen which was at the lowest brightness setting. It's a Galaxy S3.
    Wtf? My battery dropped 50% in a matter of minutes.-2013-10-27-10.59.55.png Wtf? My battery dropped 50% in a matter of minutes.-2013-10-27-10.59.37.png
    Can anyone explain why this might have happened or how to prevent it in the future? Thanks!
    10-27-2013 01:25 PM
  2. Motogameruk's Avatar
    All I can say is that the battery may have been giving a false reading when it said it was 100%.
    My old phone (razr i) would sometimes jump to 100% when I plugged it in to charge, therefore it would not charge as it thought it was full. It would then jump down to its actual battery level.
    Hope this helps
    10-27-2013 04:20 PM
  3. Austin Pritchett's Avatar
    check your charger. My Galaxy Tab 2 7.0 was having similar issues and it ended up being due to the charger being defective. Other than that, it might be the battery.
    10-27-2013 06:00 PM
  4. Aryeo's Avatar
    Hmm thanks to you both for your answers. I'll check the charging cable/charger and just see if it happens again.
    10-27-2013 10:40 PM
  5. josearmz10789's Avatar
    If nothing works try a factory data reset as most of the time it takes care of bugs.
    Sent from my N9500 using AC Forums mobile app
    10-27-2013 10:47 PM
  1. Charger/battery problem
    By trckdck in forum Samsung Galaxy SIII I9300
    Last Post: 10-31-2013, 10:13 AM
  2. Parts of android 4.4 in 4.3?
    By AndroidDev01 in forum Android 4.4 KitKat
    Last Post: 10-29-2013, 10:43 PM
  3. HELP! TWRP Broke my Neux 7? STUCK ON X SCREEN!
    By too lame to come up with a good username in forum Google Nexus 7 Tablet (2012)
    Last Post: 10-27-2013, 02:12 PM
  4. Can I use Verizon sim card in m919 (t-mobile) s4?
    By Jon Potter in forum Samsung Galaxy S4
    Last Post: 10-27-2013, 01:23 PM
  5. Android 4.4 in 4.4
    By AndroidDev01 in forum General News & Discussion
    Last Post: 10-27-2013, 11:05 AM
