1. markfranklin1970's Avatar
    Hi there
    I have the Samsung Galaxy Tab2 10.1 and was today notified that an update was ready. I installed this which was the upgrade to 4.2.2
    However since then, none of my apps will work. There is a short pause before I get:
    "Unfortunately Coin Dozer has stopped"
    "Unfortunately Lookout has stopped"
    "Unfortunately Tiny Castle has stopped"
    "Unfortunately Candy Crush Saga has stopped"
    etc.
    I tried a reboot a couple of times but that didn't help. Checked to see if Upgrades were available for all affected apps but there are none.
    This is a nightmare! Would anyone be kind enough to help me?
    Thanks so much in anticipation,
    10-29-2013 02:54 PM
  2. Golfdriver97's Avatar
    Hi there
    etc.
    Welcome to the forums. You can try to wipe cache in recovery. Here is how: http://forums.androidcentral.com/sam...2-s3-tab2.html
    10-29-2013 03:06 PM
  3. markfranklin1970's Avatar
    I will give it a try... I assume that wiping the cache will not adversely affect any apps?
    10-29-2013 03:10 PM
  4. markfranklin1970's Avatar
    I have managed to clear the cache but sadly to no avail. I continue to get the "xxx has stopped" messages whichever application I try to open.
    Looking for Android support it seems that I need to refer to Samsung or the retailer. Does anyone have a suggestion of the best course of action?
    Thanks again,
    10-29-2013 03:26 PM
  5. markfranklin1970's Avatar
    I have experimented by uninstalling and re-installing one of the apps. This works, in that when reinstalled it will work correctly.
    The trouble is, with many existing apps, especially games, there is a lot of data that I do not wish to lose.
    10-29-2013 03:34 PM
  6. Golfdriver97's Avatar
    Download helium and back up the apps.
    From a Sprint Moto X
    10-29-2013 04:39 PM
  7. Paramedic_nz's Avatar
    Hi I too just had the 4.2.2 upgrade run on my Galaxy Note 8 - Firefox, arcos video both keep crashing. Multi Window disappeared.
    Have been able to get multi window working (read other thread)
    Have had to re-install apps that have crashed - they seem to crash after installing individual application updates from PlayStore, maybe issues with application updates installing after upgrade to 4.2.2 ???
    Seems like a lack of proper testing ????
    10-29-2013 05:33 PM
  1. Note 3: Who uses the stylus, and what for?
    By thebignewt in forum Verizon Samsung Galaxy Note 3
    Last Post: 02-27-2014, 06:34 PM
  2. Help! Phonepad colors
    By stryper in forum HTC One M7
    Last Post: 10-29-2013, 09:56 PM
  3. Any reason NOT to update to 4.3?
    By PhobicCarrot in forum Samsung Galaxy S4
    Last Post: 10-29-2013, 09:04 PM
  4. Updating will brick?
    By JakeTheGiratina1 in forum Sprint Galaxy S III Rooting, ROM's, and Hack's
    Last Post: 10-29-2013, 05:57 PM
  5. "Data Usage Cycle" in settings help?
    By jfk902222 in forum General News & Discussion
    Last Post: 10-29-2013, 04:01 PM
