1. Davidzior's Avatar
    Hello all.
    I've got an annoying problem with my Galaxy S3 (Android 4.1.2). The battery is draining very fast by process called "media". I've tried to clean all data in programs, that have something in common with media, but nothing helped. What do you suggest to do with this? Also the charging of battery takes more time than usuall. Everything is on the screenshot:
    Also as you kan see above there are processes called:
    sdcard- I don't have any sd card installed
    Chrome- I'm not using it right now- it's turned off
    Mediaserver- I think it has something in common with "media" process
    What I can do to disable Media?
    Thanks in advance
    Ps. Sorry for my bad English.
    11-05-2014 02:17 PM
  2. Aziel Oropeza's Avatar
    To be honest idk what to tell you. never had this problem while i was on 4.1.2. By the time my kitkat update was ready, i went for it
    11-05-2014 02:21 PM
  1. Why can't I hear the person when I am on a call (LG G3)?
    Last Post: 11-29-2014, 06:00 PM
  2. How do I access my Downloads from a pc connected by usb?
    Last Post: 11-06-2014, 03:14 AM
  3. Autovoice and Punctuation?
    By XxStupendousManxX in forum Ask a Question
    Last Post: 11-06-2014, 02:01 AM
  4. Media links
    By butterfly210 in forum Ask a Question
    Last Post: 11-05-2014, 04:10 PM
  5. Why is there a green robot on my phone not doing anything?
    Last Post: 11-05-2014, 02:12 PM
