1. JJMcK83's Avatar
    Hi everyone, so a few days ago, my Samsung Galaxy Tab 2 7.0 got a little wet, not submerged or anything. So it started acting weird, like opening apps and showing the power off menu all on it's own. So I let it dry out for a few days and now the power and volume down buttons don't work at all. The volume up works though. So I some how got the tab to boot, and now it's stuck in safe mode.
    I did a full reset, but the buttons and safe mode issue still exists. Any suggestions of how to fix this issue?
    I have tried to hold down the power and volume down buttons, but nothing happens, held them down for 10 minutes and still nothing. If I hold power up for about 30 seconds, the tab restarts, but still nothing solved
    11-09-2017 07:45 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Chances are that the small amount of moisture affected the buttons. Try the techniques described here: http://forums.androidcentral.com/amb...e-got-wet.html
    11-09-2017 11:09 PM
  3. JJMcK83's Avatar
    Thank you for your reply. I'm going to give it a try, but it was on when it got wet, and has also been charged shortly after.
    11-10-2017 05:13 PM
  4. B. Diddy's Avatar
    Yeah, chances are that the damage has already been done. You could try bringing it to a repair shop to replace the buttons, but the problem with water damage is that it can be widespread and unpredictable, so you may also encounter other problems as well.
    JJMcK83 likes this.
    11-11-2017 01:41 AM
  5. JJMcK83's Avatar
    Yeah, not going to a repair shop. It's a Galaxy Tab 2, so it's pretty old. If I cannot get it working, then time for an upgrade.
    Do the buttons come off?
    11-11-2017 11:32 AM
  6. B. Diddy's Avatar
    I could only find a guide to replace the buttons for the original Tab 7.0, not the Tab 2 7.0: https://www.ifixit.com/Guide/Samsung...placement/6555. But I didn't search for too long -- see if you can find anything else. Good luck!
    11-11-2017 12:03 PM
  1. Question about do not disturb schedule
    By pstellato73 in forum Google Pixel 2 & Pixel 2 XL
    Last Post: 05-15-2018, 07:33 AM
  2. S8 not backing up overnight to cloud on wireless charging
    By tuscanybay in forum Samsung Galaxy S8 & S8+
    Last Post: 11-10-2017, 10:59 PM
  3. After i do the last update my gps not working, have any soloution for that?
    Last Post: 11-09-2017, 03:05 PM
  4. I want to remove pin and keep fingerprint for locking and unlocking
    Last Post: 11-09-2017, 02:41 PM
