Hi everyone; First, hope all is well and you and yours are safe & sane!
So, I have a Samsung S4 mini I257M (I know, it's older, but I love its smaller size--my mildly arthritic hands appreciate its small size.)
Anyway, the phone does not make any sounds, or for that matter, vibrate, for these features ... calendar, text messages, voicemail.
For all of those, the phone only shows the written notification on the screen. There are no sounds and no vibrations.
As far as I know, I do have all the sound settings correctly.
--- Settings/My Device/Sound - All the apropos settings are on.
--- Messaging/Settings - All the Notification settings are on.
--- Calendar/Settings - All the Notification settings are on.
--- Voicemail - Just the tiny icon in the upper Notification bar appears; no notification sound occurs.
In case it was a sim card issue, I put the sim card into another, even older, phone, and tested a calendar reminder alarm, which worked--the phone played the sound. So I suppose there's an issue with the phone itself; but I don't know what - other sounds are working fine.
Any HELP would be appreciated. Thank you!
