1. BernalSwarf's Avatar
    Kit Kat 4.4, Moto X, probably not a version issue but here goes:
    Seems that I had the phone on in my pocket and the camera Icon got oddly stuck partially visible off the bottom of the screen from an inadvertent pocket long press. Then the camera icon went away altogether
    Now when I try to add an icon in the spot where it was (lower right stock position) a black circle appears and swallows up whatever I put there. It's like a folder, but it is invisible until I try to place the camera icon or any other icon there. Acts like a black hole. I can add the camera Icon back to any home screen, just not to that far right spot on the favorites tray.
    Searched forum, no luck. Any help appreciated, TIA
    11-28-2013 12:29 PM
  2. someguy01234's Avatar
    What launcher are you talking about?
    Try clearing the data of you launcher, if it doesn't fix it, use a different launcher.
    I have similar problem with the Google launcher, where I put an icon of a specific app on the dock and it disappeared after every reboot.
    11-28-2013 12:59 PM
  1. Problem with Magnetic Cases and Note 3 S Pen Functionality
    By amariem in forum Samsung Galaxy Note 3
    Last Post: 02-24-2016, 03:50 PM
  2. Wifi grey bars problem
    By Ashhab Mulla in forum Misc. Android Phones
    Last Post: 11-30-2013, 09:04 AM
  3. Problems after the unsuccessful attempt of download of a Google Play App
    By Andrea Lixi in forum Samsung Galaxy S3 Mini
    Last Post: 11-30-2013, 12:03 AM
  4. Charging Problems
    By Sean Armstrong in forum Samsung Galaxy Note 3
    Last Post: 11-29-2013, 12:15 PM
  5. Textra sms problem.
    By BataHTC in forum HTC One M7
    Last Post: 11-28-2013, 06:43 AM
