1. Abobakr Ahmed's Avatar
    that's problems :
    1- Wifi very weak ( signal weak ).
    2 - Bluetooth don't receive programs or games.
    3- sim card working time and then separates final
    01-25-2015 07:08 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Try a cache partition wipe: http://forums.androidcentral.com/goo...tion-wipe.html
    01-26-2015 03:08 AM
  3. Abobakr Ahmed's Avatar
    Doesn't work !!!!!!!!!!!!!!!!!!!!!!
    01-27-2015 04:48 AM
  4. B. Diddy's Avatar
    It may be worth doing a full factory reset, then.
    01-27-2015 10:17 AM
  5. Abobakr Ahmed's Avatar
    doesn't work also
    i do reset factory and found same problems
    bluetooth doesn't work
    wireless very weak
    01-27-2015 10:45 AM
  6. B. Diddy's Avatar
    Was this an over-the-air update, or did you flash it yourself?
    01-27-2015 11:10 AM
  7. Abobakr Ahmed's Avatar
    i did reset factory then open phone found update 4.4.4
    i change this update to 4.4.3 but i don't know this
    01-27-2015 04:43 PM
  8. B. Diddy's Avatar
    So you're saying that you were prompted to install an update to 4.4.4 that was sent to your phone over the air, correct?
    If you want to go back to 4.4.3, you could try manually flashing that factory image. Follow the steps here: How to manually update your Nexus | Android Central. Find the correct factory image here: https://developers.google.com/android/nexus/images
    01-27-2015 07:03 PM
  9. Abobakr Ahmed's Avatar
    change update to 4.4.3 and stay same problems Bluetooth don't accept songs or apk files accept only photos and found wireless problem
    i am in crazy!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    01-28-2015 09:41 AM
  10. B. Diddy's Avatar
    What do you mean when you say Bluetooth doesn't accept songs? Are you saying that you can't pair the phone with a Bluetooth speaker or headphone?
    What do you mean that apk files only accept photos?
    For the wi-fi issue, review this guide: http://forums.androidcentral.com/amb...-problems.html
    01-28-2015 10:26 AM
  1. back light wont come on
    By Dudty47 in forum Samsung Galaxy SIII I9300
    Last Post: 01-26-2015, 07:21 PM
  2. Replies: 1
    Last Post: 01-25-2015, 07:06 AM
  3. Why isn't the air gesture on my S4 working?
    Last Post: 01-25-2015, 06:47 AM
  4. Replies: 0
    Last Post: 01-25-2015, 06:38 AM
  5. Replies: 0
    Last Post: 01-25-2015, 05:52 AM
