A
AC Question
Oversized "System Data" on Huawei P6 after updating to KitKat
My friend helped me to update from 4.2 to 4.4 using the exact same ROM flash process he used on his P6 with the same international firmware.
I am aware that the internal storage is 8GB, and that it is split in half, one half for Android OS and the other 4GB is for your own use. I will only be referring to the latter 4GB. I also have a 16GB SD card but it's not of much releveance other than almost all my media and apps being transferred to it.
After being updated to 4.4, I soon noticed I kept running out of space despite everything possible being on my SD.
Using the DiskUsage app, I discovered that almost 3GB of my internal 4GB storage is taken up by "System Data". I confirmed this as being unusual by comparing with friends' phones (also P6, both 4.2 and 4.4)
My phone is not rooted, and we used international firmware with a tweak to allow Google Apps to work correctly
