Basic installation question
I'm new to the Android world and I've noticed that when I install an app, it generally warns me that it's going to need access to various parts of the system, like Contacts or whatever. To the right of each item is a V shape that initially points down but if I click on the V, it inverts and points up (or was it the other way around)?
I assume that this is a Yes/No Allow/Disallow toggle but I'm darned if it is obvious to me which way means Yes/Allow and which means No/Disallow. Can someone enlighten me?
