1. RhinoCan's Avatar
    I'm new to the Android world and I've noticed that when I install an app, it generally warns me that it's going to need access to various parts of the system, like Contacts or whatever. To the right of each item is a V shape that initially points down but if I click on the V, it inverts and points up (or was it the other way around)?
    I assume that this is a Yes/No Allow/Disallow toggle but I'm darned if it is obvious to me which way means Yes/Allow and which means No/Disallow. Can someone enlighten me?
    07-05-2015 10:42 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! I believe that just allows you to expand the category to see more details. Android currently doesn't allow you to pick and choose permissions when installing an app.
    RhinoCan likes this.
    07-06-2015 02:36 AM
  1. Question and keyboard and the edgo
    By Fred Wilson2 in forum Samsung Galaxy S6 edge
    Last Post: 07-08-2015, 08:46 AM
  2. Wireless charger Input questions...
    By Blazer in forum Samsung Galaxy S6
    Last Post: 07-08-2015, 07:58 AM
  3. Changing fonts and Language Question
    By agoodfella in forum LG G4
    Last Post: 07-06-2015, 10:18 AM
  4. Can i install stock android on my verizon note 4?
    Last Post: 07-05-2015, 09:51 PM
  5. New S6E question regarding "sync"
    Last Post: 07-05-2015, 08:20 PM
