1. warpme11's Avatar
    usb device not recognized after installing smart switch-https___i537.photobucket.com_albums_ff334_warpme11_1_zpsw3zifb8q.png
    usb device not recognized after installing smart switch-https___i537.photobucket.com_albums_ff334_warpme11_3_zpscnnontqy.png
    i installed smart switch but usb device not recognized when i hook up the phone galaxy core prime g360h i changed cables and when i try other samsung phone it can connect and COM port is open and detected on odin
    01-21-2019 06:44 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! According to the help site, the phone needs to have at least 1.5 GB of RAM -- your phone has only 1 GB:
    https://forums.androidcentral.com/e?...token=JrFF7rJv
    https://www.gsmarena.com/samsung_gal...prime-6716.php
    Try using Kies instead.
    01-21-2019 01:35 PM
  3. warpme11's Avatar
    https://forums.androidcentral.com/e?...token=N3WzXj2u
    Hi i installed kies as u said and still the same error
    01-22-2019 02:03 AM
  4. B. Diddy's Avatar
    Did you install Kies 2.6 or 3? I'm not sure which version is the right one for you phone, but see if the same thing happens with the other version.
    01-22-2019 11:19 AM
  5. warpme11's Avatar
    i did install 2.6 and 3.2 but didn't do the trick same error
    01-24-2019 07:33 AM
  6. methodman89's Avatar
    What is the setting you have here in Developer Options?
    01-24-2019 11:54 AM
  7. warpme11's Avatar
    nope cant go to that screen when i turn on it directs to wipe reset data options and android no command error
    01-26-2019 04:30 AM
  8. warpme11's Avatar
    little help please
    02-01-2019 07:26 PM
  9. Spawnlives's Avatar
    Just curious you mention odin. Are you running both programs at the same time.
    Odin and smart switch/Kies don't play nice with each other and will cause issues.
    Error message USB device not recognised usually is a cable or driver problem are you connected directly to a USB 2 port on your PC.
    02-02-2019 04:52 AM
  10. warpme11's Avatar
    switch/kies is not running only odin i tried also plugging only one usb cord from the pc to the phone still not reading but when i plugged other android phone i can see its communication port and odin will detect it automatically for flashing and btw the battery is fully charged and phone set to odin download mode
    as what methodman posted i cant access that since turning on the phone will immediately boot to recovery mode
    02-02-2019 07:56 AM
  11. Spawnlives's Avatar
    Not sure what's happening I'm still leaning towards a cable issue even it does read other android devices. I had the same issue with a second hand s8 and the cable that came with it had to use another cable.
    Is it still showing up as an error when plugging in.
    Have you tried different cables(data) or even a different PC.
    Try uninstalling smart switch/kies (reboot PC afterwards). Note: I'm not sure if this removes the usb drivers but it is worth while reinstalling them anyway.
    https://www.thecustomdroid.com/downl...ng-usb-driver/
    Also to start with use a file explorer to see if phone is recognised ( while in normal/system mode ) as Odin can be a bit touchy in regards to it's com link.
    What version of Odin are you using.
    Not sure what you mean by phone rebooting into recovery when enabling developer options as generally it shouldn't happen.
    Also curious as to what you want to do to your phone.
    02-03-2019 01:43 AM
  12. warpme11's Avatar
    ive tried 5 different cables and even original samsung cable came from my friend's s9 still not working but the s9 reads automatically hell even those crap cables from universal charger works tried it in different computers since i work in office still zilch but s9 works perfectly
    im using odin 3.2 when i turned on the phone it should be booting to main screen right but what happens is that after booting on it show the android dummy can with a no command phrase with it and after opens to recovery mode where you can reset the the phone and etc . didnt enable dev options as i said the phone will boot to recovery mode cant even go to main screen
    i want to reflash the phone
    02-03-2019 02:47 AM
  13. methodman89's Avatar
    Are you saying your phone doesn't work, it doesn't even boot to the home screen?
    02-03-2019 07:36 AM
  14. warpme11's Avatar
    yes it boots directly to recovery mode
    02-03-2019 07:58 PM
  15. Spawnlives's Avatar
    Have you tried a factory reset from recovery.
    02-06-2019 04:25 AM
  16. warpme11's Avatar
    yes and nothing happens
    i did was and nothing happens.
    -factory reset
    -wipe cache partition
    -change cables to detect COM port on PC
    -change cheap usb cables to original samsung cable from my friend
    -tried different computers for detecting COM port on PC
    -used samsung kies/switch/samsung usb driver on different computers uninstall>reboot>clean registry>install to change drivers
    now the phone keeps stuck at galaxy core prime logo and restarts
    02-06-2019 04:35 AM
  17. Spawnlives's Avatar
    So it's now booting to logo and restarting seems better than booting into recovery ( which it shouldn't by itself )
    You could keep trying the wipe cache/dalvik and factory reset.
    Have you tried removing the battery for 10 minutes or so then boot up.
    Another issue that's been reported is it might be a faulty battery which will cause Stange effects. Note: even though the phone may say it is charging/charged it is not an indication of a good battery.
    02-07-2019 08:56 PM
  1. Whatsapp pictures not showing in my gallery
    By MCENG2002 in forum WhatsApp for Android
    Last Post: 01-24-2019, 09:13 AM
  2. Samsung S6 edge asking for password after reboot
    Last Post: 01-21-2019, 06:42 AM
  3. Android auto not showing or reading messages
    Last Post: 01-21-2019, 05:18 AM
  4. Android 8.1 installation stuck even after a reset to factory settings
    Last Post: 01-21-2019, 04:31 AM
