1. dougltc's Avatar
    I want to be ready for Lollipop's Smart Unlock feature with NFC tags in my car, bedroom, man cave, etc...
    What is a good starter pack of NFC tags? Decent quality, good value?
    I prefer Amazon first, eBay second but will use a 3rd party site...
    NOTE: Searching NFC tags on Amazon/eBay turns up a
    lot of hits.. Just looking for a recommendation from someone who has used them...
    11-04-2014 08:15 AM
  2. dougltc's Avatar
    Really? No one?
    11-07-2014 08:12 AM
  3. asherN's Avatar
    Issue with NFC tags is the limited distance. Unless you're right next too them, they're useless.
    11-07-2014 10:38 AM
  4. someguy01234's Avatar
    I have the Moto Skip so I use it both for my Moto X and Nexus 7, but you basically have to turn on the screen and tap the back of the device on the tag to have it unlock.
    11-07-2014 10:40 AM
  5. benhaube's Avatar
    NFC unlock is a waste. I got a Skip with my moto x, and it is pretty much useless. I'm much happier using trusted Bluetooth with my moto 360.
    11-07-2014 04:49 PM
  6. unrealmp3's Avatar
    Can be useful as a way to unlock your smartphone if you can't remember your PIN or if it doesn't work for some reason.
    Add your credit card as a trusted device, so this way you have a workaround.
    11-19-2014 09:49 AM
  7. Kinger23's Avatar
    Gotta agree with the others who talk about using BT devices instead of NFC. I have my NFC turned off normally but have added my BT car stereo as a trusted as really the only time I don't want to be unlocking is when it's in it's cradle and I want to bring up Maps or something.
    11-19-2014 11:46 AM
  8. theduder's Avatar
    The NFC tag type you need should be dictated by the phone you have.
    Also, for the car you don't need a tag, just use the in-car BT device as a trusted one. I'm doing that now so that every time I'm in the car and paired I don't need a pin.
    11-19-2014 12:50 PM
  1. Question about Lollipop and Bluetooth
    By JimA in forum Samsung Galaxy Note 4
    Last Post: 11-05-2014, 12:57 PM
  2. Droid Turbo: Question for those who are (going) naked?
    By billbrobaggins in forum Motorola Droid Turbo
    Last Post: 11-04-2014, 08:52 PM
  3. Replies: 3
    Last Post: 11-04-2014, 08:17 AM
