1. jevian bazouza's Avatar
    Hey,i just bought a Samsung galaxy S5 every thing is okay but the Play Store won't Update It's always on 4.8.20 ! Please someone Helps me.
    11-07-2014 02:36 PM
  2. Alex Wetzel's Avatar
    Go on the Internet and install the apk file for the 5.0.37 update. Just search Google for play store 5.0 apk download.
    11-07-2014 05:00 PM
  3. BEARD GANG's Avatar
    Go into play store click the side menu then click settings go down and click build number it will update
    11-07-2014 06:32 PM
  4. colyn1353's Avatar
    Have you logged into the play store with your password?? You can still browse without logging in but you cannot download..
    11-07-2014 06:58 PM
