1. anon(55900)'s Avatar
    Nexus 7 2013 WiFi, kit at 4.4.4. If I side load lollipop with wugfresh and the phone gets wiped. Won't Google reinstall all my apps and settings automatically? In this situation do I really need to wait for OTA? All my photos are automatically sent to Google plus. Songs that I have on phone can quickly be added back on through my laptop USB.
    The deed is done, Lollipop is now on my Nexus 7 2013 WiFi, used Wugfresh, took a pic with my Nexus 4 as the 7 was still downloading updates. Yesss, Android even remembered the folders I'd set up, what icons/Apps that I had on the start page and where they were located on the screen, cool.
    frankenhooker likes this.
    11-13-2014 09:09 PM
  2. Golfdriver97's Avatar
    I don't see any reason why this wouldn't work. Have you started yet?
    anon(55900) likes this.
    11-13-2014 09:41 PM
  3. 1210saad's Avatar
    Yes google will reinstall you apps, your good to go.
    11-13-2014 09:45 PM
  4. anon(55900)'s Avatar
    Did it!
    11-14-2014 02:31 PM
  1. Replies: 1
    Last Post: 11-13-2014, 01:49 PM
  2. Replies: 6
    Last Post: 11-13-2014, 12:40 PM
  3. How do I know if I have battery problems?
    By doras100p in forum Sony Xperia Z3
    Last Post: 11-13-2014, 10:19 AM
  4. Replies: 1
    Last Post: 11-12-2014, 07:15 PM
  5. Update to Lollipop if rooted?
    By oscari in forum Android 5.0 Lollipop
    Last Post: 11-12-2014, 05:42 PM
