1. Converted007's Avatar
    Hi,
    I hope anyone can help me...
    Im desperate. My Nexus 7 (2013) Wifi is unusable since the update to Android 5.0.
    It keeps giving me the same error 'android.process.acore' over and over again.
    The contacts app is crashing constantly. I cant even open Hangouts.
    I tried sideloading the ota. I system flashed the 5.0 image. No luck at all. The error keeps on coming back.
    Im at this point on returning it back to Google...
    11-15-2014 08:02 PM
  2. N4Newbie's Avatar
    Just out of curiosity, are you trying to load the Wi-Fi only version on a Wi-Fi/LTE Nexus 7?
    11-15-2014 08:28 PM
  3. Converted007's Avatar
    The wifi version. Had sideloaded the correct ota. And also flashed the correct system image...
    11-15-2014 08:31 PM
  4. xban1's Avatar
    Flash it back to 4.4.4 and what for the ota update
    11-15-2014 08:39 PM
  5. Converted007's Avatar
    I was thinking the same lol. But is there a chance that the error may come back when i update my device with the 5.0 ota? Or maybe i will get the same error on 4.4.4 as well...
    11-15-2014 08:47 PM
  6. xban1's Avatar
    It might be a technical error when you flashed manually to 5.0, but did you have this error before with 4.4.4? If not then you won't have it if you flash it back
    11-15-2014 08:49 PM
  7. Converted007's Avatar
    Nope. Never saw this error on 4.4.4. Is it good that i wipe the dalvik/system cache also? Or thats not neccesary?
    11-15-2014 08:52 PM
  8. xban1's Avatar
    No when you flasg it back, it will delete itself
    11-15-2014 09:46 PM
  9. Converted007's Avatar
    Thanks:-) Already flashed the 4.4.4 firmware. I hope when the OTA update pops up the error wont come back. How big is that chance?
    11-16-2014 07:05 AM
  10. xban1's Avatar
    Nearly guarranted, don't worry.
    11-16-2014 10:38 AM
  11. Converted007's Avatar
    Thanks:-) Looking forward to that OTA lol.
    11-16-2014 10:44 AM
  12. xban1's Avatar
    Same haha
    11-16-2014 11:39 AM
  13. anon(55900)'s Avatar
    I used Wugfresh to install factory image, Nexus 7 wifi only, no problems here, did it Friday and been playing it hard with no problems.
    11-16-2014 11:58 AM
  14. ljxdaly's Avatar
    my flash of the factory image had a similar result. when i did a factory reset, all was cleared up, and my n7 2012 is doing very well with 5.0
    11-16-2014 12:14 PM
  1. Severe Speakerphone Echo with Flip case
    By Tom Furlan in forum Motorola Droid Turbo
    Last Post: 11-19-2014, 11:34 AM
  2. Replies: 2
    Last Post: 11-16-2014, 05:00 PM
  3. Replies: 1
    Last Post: 11-15-2014, 08:23 PM
  4. spot on the camera lens
    By Bdot-1 in forum Samsung Galaxy Note 4
    Last Post: 11-15-2014, 08:19 PM
  5. What do you consider to be lag on the Nexus 7 2013?
    By Seth Lamb1 in forum Google Nexus 7 Tablet (2013)
    Last Post: 11-15-2014, 06:47 PM
