1. Yazan Abdullah's Avatar
    so has anyone experienced the following issues after updating their nexus 5 to android 5?
    1-wifi connectivity.
    2-lag
    3-battery drain
    butterfly210 likes this.
    11-16-2014 03:29 AM
  2. Podolsky's Avatar
    All of them, plus games crash, and camera app
    Posted from my new Nexus 5
    11-16-2014 04:14 AM
  3. N4Newbie's Avatar
    I'm doing fine. I don't play games (other than Mobility Solitaire) but everything else is working crash-free and not noticing any significant difference in battery life.
    11-16-2014 04:20 AM
  4. N4Newbie's Avatar
    I will add that I have no Wi-Fi problems at all. None at home, and none at work where I connect to four different routers depending on my location in the building.
    Cell signal seems to be a bit stronger in my home where I was rarely over two bars before.
    And, no, I am not noticing any lag.
    As with 4.4.4, if I had to guess, I suspect that you guys may have apps installed which are not yet 5.0 compliant.
    11-16-2014 06:37 AM
  5. Blaize19's Avatar
    No issues here. WiFi is fine and both it and the cell radio seem to be stronger. No lag, and my battery life seems somewhat better.
    Posted via my Nexus 5 via the Android Central App
    11-17-2014 10:59 AM
  6. daihard2008's Avatar
    No Wi-Fi or lag issues here, either. I may have a battery drain issue, but it's hard to tell at this point.
    11-17-2014 12:56 PM
  7. flattie's Avatar
    No WiFi issues here; it has been rock solid.
    I've had the occasional app crash, but nothing to get upset about.
    Generally, 5.0 has been very smooth, although now and again it does seem to hit a road bump. Not surprised though as there are so many changes that anyone expecting a completely bug free experience at this point were probably expecting a little too much.
    I expect major bugs to be squashed over the course of the year with spit and polish being applied to 5.1 (as well as some tasty new features). Speaking of which, has 5.0 been out long enough to start speculating for 5.1? 😝
    daihard2008 and Jonneh like this.
    11-17-2014 01:27 PM
  8. Shargeel Kiani's Avatar
    No wifi lag or any sort of issue. Though android 5 is a lot smoother and my battery life has increased to a noticeable extent Thumbs up for google's project volta.
    11-17-2014 01:38 PM
  9. butterfly210's Avatar
    Try silent mode and auto brightness...
    *My Sexy Note 4*
    11-18-2014 01:59 PM
  10. N4Newbie's Avatar
    *My Sexy Note 4*
    Why?
    Both of these functions work exactly as intended. They may not work as you would like them to, but they do work as designed, hence they are not bugs.
    11-18-2014 02:07 PM
  11. butterfly210's Avatar
    Why?
    Not me I have not updated any of my devices... But other AC members have and those r two features they are complaining about plus Wi-Fi connectivity.... Doubt they r lying... Lucky u have no issues.. Both Samsung and google have spoken about a few bugs and a work around!!
    http://www.expertreviews.co.uk/mobil...-in-android-50
    *My Sexy Note 4*
    11-18-2014 06:33 PM
  12. N4Newbie's Avatar
    But as I said, Silent Mode and Auto Brightness may not work the way you (or others) would like them to, but they are working exactly as designed. They are not bugs, but the result of new design decisions made by the Android development team.
    As to Wi-Fi, apparently some people are having difficulties, but many more (or even most) are not. New operating system releases always come with their fair share of no-longer-compatible apps which can wreak all sorts of havoc, I strongly suspect that the folks who are having Wi-Fi issues will eventually track them to something else they have installed and not the OS itself.
    daihard2008 likes this.
    11-18-2014 07:31 PM
  13. butterfly210's Avatar
    Well either way... I m glad it's not available for note 4 as yet.... When it is hopefully all the major kinks will be ironed out!!!
    *My Sexy Note 4*
    11-18-2014 09:36 PM
  14. consigliero's Avatar
    Maybe is problem of Samsung, with Nexus I didn't found this " bugs "
    11-19-2014 01:24 AM
  15. thekid17's Avatar
    I can't sign-in to network. I get a blank white screen. Any one have this and do you have a fix?
    11-19-2014 07:43 AM
  16. N4Newbie's Avatar
    What network? Can you be more specific?
    11-19-2014 07:55 AM
  17. thekid17's Avatar
    My work network needs a password put in. You get that WiFi symbol up in the left corner with the question mark. I click on it and get a blank white screen instead of a place to put the network name and pass code.
    11-19-2014 08:43 AM
  18. mattopotamus's Avatar
    I will beg the differ about silent mode. That is clearly a bug. The tablet has a typical "silent" mode. It was an oversight/bug and will be fixed in 5.0.1. The Do Not Disturb features are definitely not intended to replace silent.
    I have had zero issues though. No app crashes, no slow down, no wifi/bluetooth issues. Absolutely running just fine. I did set the device up as new.
    11-19-2014 09:33 AM
  1. Any App to take screenshots?
    By fortherest17 in forum Android Apps
    Last Post: 07-14-2015, 08:44 PM
  2. Why can't I download any app from the Play Store?
    By ImNotRobot in forum Google Play Store
    Last Post: 11-17-2014, 04:47 PM
  3. What can I do to remove DEMO which has appeared on all my screens?
    By Sylvana Zammit in forum Ask a Question
    Last Post: 11-16-2014, 04:33 AM
  4. Any Nexus 5 users running on Android 5 without bugs and glitches?
    By Yazan Abdullah in forum Ask a Question
    Last Post: 11-16-2014, 03:28 AM
  5. Replies: 0
    Last Post: 11-16-2014, 01:57 AM
