1. Shargeel Kiani's Avatar
    Guys i just flashed final image on my nexus 5, everything is working fine but the only problem is that there is no gallery folder anywhere... Any suggestions?
    DLK1 likes this.
    11-16-2014 05:20 AM
  2. frankenhooker's Avatar
    Android 5.0 got rid of Gallery.
    butterfly210 likes this.
    11-16-2014 05:34 AM
  3. Shargeel Kiani's Avatar
    Can u suggest a good app as a gallery replacement? Thanks
    11-16-2014 06:00 AM
  4. N4Newbie's Avatar
    Gallery app has been on the way out since at least 4.4.3 if I recall correctly. In 5.0 it is finally gone.
    Google intends that you should now use the Photos app - it's there, look for it.
    11-16-2014 06:33 AM
  5. Shargeel Kiani's Avatar
    Got it thanks
    11-16-2014 09:12 AM
  1. Nexus 5 sprint to tmo settings?? Help
    By smilinzena in forum Nexus 5 Rooting, ROMs, & Hacks
    Last Post: 12-03-2014, 07:46 PM
  2. Needing help with widget's
    By kristen2413 in forum Ask a Question
    Last Post: 11-17-2014, 04:13 AM
  3. help
    By EricCollins6669gmailcom in forum Samsung Galaxy S3
    Last Post: 11-16-2014, 07:25 AM
  4. What is a good root guide for the Verizon Note 3?
    By Matthew Motamedi in forum Samsung Galaxy Note 3
    Last Post: 11-15-2014, 11:22 PM
  5. Flashing OTA Help
    By vonedaddy in forum Nexus 5 Rooting, ROMs, & Hacks
    Last Post: 11-15-2014, 12:28 PM
