1. daihard2008's Avatar
    Using Lollipop for a few days, I've noticed that the LED doesn't come on during charging. I've tried both wired and wireless charging, and it's the same. Is there a way to change it so the LED will come on when I plug the phone in for charging?
    TIA
    11-17-2014 10:48 AM
  2. N4Newbie's Avatar
    Um, it never came on on the Nexus 5 - so, why is it an issue now?
    There may be an app that will do what you want. Light Flow comes to mind, though I have never used it. See https://play.google.com/store/apps/d...roid.lightflow
    daihard2008 likes this.
    11-17-2014 10:52 AM
  3. daihard2008's Avatar
    Oh, it must have been a feature of the custom ROM (AOKP) I was using until I flashed the stock Lollipop. I just took that for granted as a standard feature!
    I will try Light Flow. Thanks!
    11-17-2014 10:56 AM
  4. N4Newbie's Avatar
    Be sure to check out the Light Flow comments. I'm not sure about its Android 5.0 compatibility...
    11-17-2014 11:50 AM
  5. daihard2008's Avatar
    Yeah, looks like the app isn't compatible with Lollipop. Thanks for the warning.
    11-17-2014 12:17 PM
  1. Did anyone ever find a tempered glass protector with no halo?
    By rvhs03 in forum Samsung Galaxy Note 4 Accessories
    Last Post: 12-01-2014, 06:12 PM
  2. M8 One Standard Charger Slow Charging
    By Steve Carton in forum HTC One M8
    Last Post: 11-17-2014, 12:57 PM
  3. No emoji icon on the long press keyboard menu
    By bubbbab in forum Android 4.4 KitKat
    Last Post: 11-17-2014, 10:26 AM
  4. Did anyone ever find a tempered glass protector with no halo?
    Last Post: 11-17-2014, 10:03 AM
  5. Replies: 0
    Last Post: 11-17-2014, 09:25 AM
