1. irwinr's Avatar
    Hey everyone,
    My girlfriend and I both have Nexus 5's that were running Kitkat. We just upgraded to Lollipop and there are two issues driving us nuts: To either answer a call or dismiss/snooze an alarm, you have to enter your PIN to unlock the phone first.
    On Kitkat you did not have to do this. Does anyone know if you can revert back to the old behavior?
    11-20-2014 02:33 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! That should not be happening. Are either of your phones rooted or encrypted? Do either of them have any 3rd party security or lockscreen apps installed?
    If the answer is no to all of the above, then try wiping the cache partition, which won't erase any personal data. Be aware that the process takes 5-10 minutes on a Nexus 5. http://forums.androidcentral.com/nex...-recovery.html
    This probably doesn't have anything to do with it, but go to Settings>Sound>Interruptions, and make sure it's set to Always Interrupt.
    11-20-2014 03:44 PM
  3. Knudroid's Avatar
    Some good advice from B.Diddy there. I have not had this problem, but I also have the face unlock feature enabled, which totally rocks now. I seriously recommend using it. When properly configured, you'll never need your pin again.
    B. Diddy likes this.
    11-20-2014 04:46 PM
  4. Sicily1918's Avatar
    It sounds like this guy's problem on his N4:
    http://forums.androidcentral.com/goo...p-upgrade.html
    It was an app (in that case, Velis Auto Brightness).
    Do you have anything like that (e.g., Lux)?
    11-21-2014 01:29 AM
  1. I don't have an option to completely disable apps???
    By zfrawg in forum Android 4.4 KitKat
    Last Post: 11-25-2014, 03:13 PM
  2. Last user to get Lollipop OTA update on Nexus 5
    By elusive11 in forum Android 5.0 Lollipop
    Last Post: 11-21-2014, 10:45 AM
  3. Moving apps and app data from Note 3 to this tablet
    By azkimbers in forum Samsung Galaxy Note Pro 12.2
    Last Post: 11-20-2014, 03:36 PM
  4. Motorola stock camera or Google Camera?
    By Ping Man in forum Motorola Droid Turbo
    Last Post: 11-20-2014, 03:13 PM
  5. How can I open my S4 to get the data if my screen is dead?
    By kagisan94 in forum Ask a Question
    Last Post: 11-20-2014, 02:32 PM
